does anyone know how many gallons each bar on the 2012 Honda Insight corresponds to? According to Honda, the 2nd gen Insight (2010-2102) has a 10.6 gallon tank. I counted each bar on the fuel gage and it's about 25 bars (I think). The reason I ask is the MID on my Insight (2012 EX), says I'm getting 49.1 mpg. I bought it new last Saturday 4/28 and I've driven 224 miles so far. The fuel indicator is almost at the half range. If my calculations are correct, I should divide 224 miles by 5.3 (half of 10.6) to get an mpg of 42.2. But how come my MID says 49.1?
I have a 2012 Insight with about 12K on it now, and although I haven't tried to compare the fuel indicator level to mileage (I don't think that can be done with much accuracy), my MID MPG was about the same as yours for the first tank. I have since gotten as high as 57.4 MPG on the MID for a single tank - about 8.5 gallons to fill up, and when I have compared the MID to an actual miles/gallons it was within .2 to .4 MPG, both low and high. My MID is reasonably accurate, and I have continued to get beter mileage the longer I have had the car. I thought I knew how to drive a hybrid for mileage, as I also have a Gen1 Insight, which consistently has gotten great mileage (also the reason I bought a 2012), but was put off by the lower figures I initially was seeing when I had only had the 2012 a short time. I have to think that break in and adjusting to a much different car have had something to do with it. Incidentally, my salesman at the Honda dealership drives a 2010 Insight and claims he has never gotten more than 47 MPG! (almost made me get a Prius, but then I checked with some other Gen2 owners who got much better MPG)
I don't know about the Insight (yet, but very soon) but most vehicles I've owned have fuel level indicators (guages, bars, etc.) that are far from linear. Much of that has to do with the shape of the tank and how far the level float gets buried into the fuel when full. It takes a while for the level to drop down to where the float is actually floating before it can start to indicate anything but a full tank. As such the first part of the tank always seems to last longer than the last portion.
I would also suspect that your mpg varies a bit based on the fuel load being carried.
You can run the gas gauge down close to empty and you'll get a yellow "low fuel" warning light, you can then switch the MID to"Range" and drive to the point it just switches to zero, pull into a gas station and filler up. It'll take 9.3 gal. Not too bad for a 10.6 gal tank!
The MID mpg gauge was pretty accurate when I first got the car. But as it got older it's mpg improved. Also as I changed my driving style to do max ev mode and good battery management, the mpg and the MID optimistic error got higher and higher.
Fly'n the Blue Bird since May 30, 2009
Yep - in metric terms the Insight supposedly has a 40 litre tank. I've run past 0 miles range on 2 or 3 occasions now and the most I've ever managed to squeeze in was about 35 litres.
I get 65-70mpg per trip depending on traffic and about 22-25 miles per bar on the fuel display. You'll probably get the same depending on your mpg per trip.
I have reached the 0 km range in many occasions and i still had 5 litres of fuel inside the tank, another 60-80 km at least.
When the red low-fuel light appears you have another 6 litres of fuel.
Thanks I did not know of this. I've been close with one bar left several times. But never knew how much was really left.
While that's true, the gauge could have easily been calibrated to compensate for that before the car went into production. The urban legend is that this is not done with cars because then people constantly see the gas gauge dropping and complain about their car being a gas hog.
