Bridgestone Ecopia tires - Insight Central: Honda Insight Forum
Old 02-06-2013, 08:58 AM   #1 (permalink)
jc2bg's Avatar
Default Bridgestone Ecopia tires
Recent threads mentioning the value of the Bridgestone Potenza tires got me thinking today [always dangerous]. My 2013 EX came with a Bridgestone tire I've not heard mentioned on the forum: Ecopia P175x60x15R. Does anyone have experience with this tire, or is it something too new to have a track record at this point? Although I haven't been driving much lately, so far I couldn't be happier with the feel and handling. Max rating listed on the tire is 40 psi, but it came off the dealer lot at 50 psi all around. Firm but certainly not harsh ride, and corners very nimbly--just the way I like a small car to drive. The Ecopia is a M-S tread; seems like a very versatile pattern for the Midwest U.S., and no highway noise that I can discern.
Just for curiosity's sake, lmk if you have thoughts on this tire.
2013 Insight EX (w/o nav) -- Findlay, Ohio
jc2bg is offline   Reply With Quote
Old 02-06-2013, 11:50 AM   #2 (permalink)
samwichse's Avatar
I've got a friend who put a set on her Prius about a year ago now, she's been pleased with the noise and fuel efficiency.
Sam
-OBDIIC&C
-IMAC&C
-Lower grill block
Old 02-06-2013, 04:42 PM   #3 (permalink)
jc2bg's Avatar
Default Ecopia tires
Thanks for your input, Sam.
Old 02-06-2013, 05:13 PM   #4 (permalink)
Maybe this will help.
Car Tires and Truck Tires | Bridgestone Tires
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 02-06-2013, 06:04 PM   #5 (permalink)
For the European I2s with 185/55R16 tyres, I've notice that both the Ecopia EP150 and the Turanza ER300 Ecopia are available. These both seem to have pretty low rolling resistance.
At the moment the EP150 looks most likely to by my next set of tyres but I only seem to be getting through about 1mm of tread every 8k miles at the moment. Another 1mm to go before I consider replacing them.
Uriel is offline   Reply With Quote
Old 02-06-2013, 11:18 PM   #6 (permalink)
I have the Bridgestone Ecopia 422 P175x60x15R on my 2010 EX. They are better that the Avid Ascend T, which I traded in. They are quiet on the highway and when going straight. There is some tread noise when going around corners. The Avid Ascends felt like snow tires and had poor wet traction. So far the Bridgestones have been good on traction but I have not driven in deep snow yet.
As far a mileage goes, I think they are similar to the stock Dunlops SP3's mine came with. It is hard to judge, as new tires will have worse mileage than older tires until the break in, and the larger diameter due to more tread would account for a 2.5% drop in mileage. Since I bought them in October as the temps dropped, the mileage was lower due to winter cold and winter gas as well.
2010 EX Sky Blue since 11/2/09
insightfulone is offline   Reply With Quote
Old 02-07-2013, 06:15 AM   #7 (permalink)
Default New Dunlop tyre range, Dunlop Bluresponse
These tyres are aimed at the Michelin Energy saver + tyre range, some sizes are rated B for LRR and A for wet braking and a single wave for noise, ie lowest noise rating.
Regret they are not avaliable in Insight G1 size, but a good selection for the 15 and 16 inch rims for non G1 hybrids
London UK.
Old 02-07-2013, 06:54 AM   #8 (permalink)
jc2bg's Avatar
Default Ecopia info
Wow. More feedback on these than I'd expected. Thanks to all. You have definitely given me some food for thought, including the concept of newer tires yielding less fuel economy. Makes sense though.
JC
Old 02-07-2013, 08:36 AM   #9 (permalink)
Mine came with Bridgestone Turanza 185/55/R16 which was basically not adequate for my daily routine and the crappy roads we have here in Greece.
Trashed them for Michelin Energy Savers 195/55/R16 and i have loved the car even more since in terms of comfort and overall performance. And i always keep them inflated to 42-44psi for maximum performance.
Old 02-07-2013, 08:57 AM   #10 (permalink)
Default Re: Bridgestone Ecopia tires
Which Turanza were they? I'm guessing ER370s, which are supposedly significantly inferior to the ER300s.
Sent from my MB526 using AutoGuide.Com Free App
