Engineering stainless trinket - Insight Central: Honda Insight Forum
Go Back   Insight Central: Honda Insight Forum > Honda Insight Off-Topic > Honda Insight Lounge
Old 07-16-2010, 03:03 PM   #1 (permalink)
Default Engineering stainless trinket
Well I resisted for a day or two, but mines on it's way!
Go here and watch the video
Kinekt Design
Roger Crier is offline   Reply With Quote
Old 07-20-2010, 03:04 PM   #2 (permalink)
Well I've got it now and it is quite unique! Most peeps who see it seem to like it, and the best of it is no one else has even ever seen one, let alone got one.....result.
If you look at the first picture on the website you can see what seems to be a tiny blemish in the join line on the inside of the ring. I thought it was some sort of mark from the assembly operation, and still thought that after I had looked at it for real, but once I put it under my stereo viewer (X10 mag) I saw that the marks (3 of them equaly spaced round the join line) were the tiniest stainless steel mig welds I have ever seen. At about 0.08" long and 0.008" wide they are mind bendingly small. I didn't know you could weld that small.
If you look at the first picture on the website you can see a tiny blemish in the join line on the inside of the ring. I thought it was some sort of mark from the assembly operation, and still thought that after I had looked at it for real, but once I put it under my stereo viewer (X10 mag) I saw that the marks (3 of them equaly spaced round the join line) were the tiniest stainless steel mig welds I have ever seen. At about 0.08" long and 0.008" wide they are mind bendingly small. I didn't know you could weld that small.
The only trouble with that is I cannot take the bl00dy thing apart!
Old 07-20-2010, 03:59 PM   #3 (permalink)
It's a nice thing and cleary shows your orientation (Techy Nerd) to any who spot it!!
