Thanks for the welcome guys:
Gilbert guy:
what color is your car? When I lived in Phoenix my CRX didn't have A/C but it was white so I think in some way that helped a little lol. Since you live there, I would assume your heat tolerance is higer than that of most. You should be ok, just might loose a few pounds of water every day
. I always drove with a camel pack full of water because I would drive from Tempe to Peoria for work. Traffic backups on the 202 and 101 in 115 degree heat was no fun during rushhour.
MN driver:
thanks for the info regarding the software update. I will check with honda when I get some time. The code has appeared again and I just keep clearing it for the mean time. The previous owner had the cat converters replaced at 150k so I was hoping the reflash was done then.
As for engine swaps for this car. I havent done the research yet, but has anyone tried swapping the 1.3 4cyl from the civic hybrid into an insight? The insight has some room in the engine bay so I would'nt think it would be a problem to fit. Whenever my motor goes I am thinking of trying this swap. Maybe buy a donor 03 Civic Hybrid and just swap drivetrains, wiring harness, etc.
I am about to drive up north to go snowboarding for new years. should be a 550 mile round trip. Lets see if I can do it in 1 tank (lots of hills).
