Excel spreadsheet help - Insight Central: Honda Insight Forum
Go Back   Insight Central: Honda Insight Forum > Honda Insight Off-Topic > Honda Insight Lounge
Old 01-20-2012, 12:41 AM   #1 (permalink)
Default Excel spreadsheet help
I have imported a lot of csv values between 0-255 into column A in an excel spreadsheet.
Every tenth number is always the same value 1
What i want to do is sort/filter/import it so that whenever 1 appears it moves that block of ten into a row using columns 1-10
so data in my column A is below (not actual values)
1
2
3
4
5
6
7
8
9
10
1
2
3
4
5
6
7
8
9
10
etc
I want it to look like below in ten columns
1 2 3 4 5 6 7 8 9 10
etc
How to do this?
Old 01-20-2012, 04:58 AM   #2 (permalink)
AbCaRed00's Avatar
This may be a little murky and it's been years and I'm sure there is a better way but here's a couple tactics for data manipulation that hopefully may help...
In one approach I would import similar strings of data from the Column 'A' into a reasonably powerful word processor program, dumping all the data in one long column many rows long.
The data likely may paste-in with 'line breaks' or hidden 'paragraph characters' after each number.
After pasting into the WP, edit by Find and Replace, all whole word occurances of
'1' <line break> ..or <^p> as it may be
to
<line break>'1' <line break> """
which would result in a row gap in front of each '1'; spacing the sets from the next.
Then find and temporarily replace all occurrences of
<line break><line break>
[occurring after the number in the 10th position in front of the next '1'], to
'zzzz' or some placeholder
[.. as long as it isn't in your data set;]
Next change all occurrences of
<line breaks> or <^p> to
either tabs or commas [depending on what works best importing back into the spreadsheet. ]
The data will all jam together in a one big paragraph mass with the 'zzzz' where each line break is now desired.
Change the temporary 'zzzz' back to a single <line break> and it should form up like a table in the word processor with eleven columns of numbers in text including the long column 'A'.
Finally dump the grid of numbers into the spreadsheet in numeric format.
[In a nutshell, the method changes 'return keys' to 'tabs' after introducing an extra row, then replacing and and 'preserving it' while wiping out the rest with a text marker where you want the line breaks later. The 'zzzz' text marker is meant to change back to a 'return key'/line break to denote the end of a row and form up a table.]
Another way to do it in the spreadsheet would be to paste the column of numbers in 'A'
then set cells sideways up something like
b1 =A1, c1 =A2, d1 =A3, e1 =A4, f1 =A5, g1 =A6, h1 =A7, i1 =A8, j1 =A9, k1=A10,
Copy block from B1:k10.
Move to cell at start of next group of data points i.e. to B11 and paste to k20 etc.
If there are thousands of rows it won't take long recopy and pasting repeatedly and doubling up to make for shorter keyboarding of the largest files.
What should form up is a row of numbers every ten rows forming up on the number '1' as seen in column 'A'
Select column 'A' and do a Sort
then all the number '1's should fall together with the data grouped into a table to the right.
Finally, Select, copy, paste, and format into the spreadsheet for analysis.
I hope there is an easier way or a macro that could be useable by all.
Old 01-20-2012, 05:12 AM   #3 (permalink)
Hi Peter,
I presume this is not a one off and you will be doing this over and over?
Can you describe the process of how you aquire the data in the first place?
EDIT: As in is this already in a file before you get it to excel?
Thanks
Richard
Insight owner since 7th Feb 2009
2002 Red 5 Speed MT 165,000 Miles (OBDIIC&C)
Projects Planned: IMAC&C, Rad Block, Block Heater, Grid Charger
2007 Silver A8 3.0 TDI now passing 136,000
Previous Owner of a: 2005 Silver Manual Insight with 25,000 miles. lmpg 81.9
Previous Owner of a: 2001 Black A2 1.4 TDI 87,000 miles,
All my cars are Aluminum (I think its magnetism)
richardh is offline   Reply With Quote
Old 01-20-2012, 06:41 AM   #4 (permalink)
Thanks for the ideas.
The data is in a comma delimited text file which I import into excel.
Keep the ideas comming it's all in the interest of the group.
Old 01-20-2012, 08:15 AM   #5 (permalink)
samwichse's Avatar
Oh man, this would be so easy in SAS.
In Excel, you can do it with a macro.
Just hit "record macro" set your key shortcut, then stop again to get an empty one. Hit "view macros->edit" and replace what's there with the following (as per your example of 1-10):
Code:
Sub transpose()
    Dim sourceRow, targetRow, targetColumn As Integer
    ' find first empty row in target sheet
    targetRow = 1
    While (Sheets(2).Cells(targetRow, 1) <> "")
        targetRow = targetRow + 1
    Wend
    sourceRow = 1
    While (Sheets(1).Cells(sourceRow, 1) <> "")
        For targetColumn = 1 To 10
            ' copy
            Sheets(2).Cells(targetRow, targetColumn) = Sheets(1).Cells(sourceRow, 1)
            ' delete original row (uncomment if required)
            ' Sheets(1).Cells(sourceRow, 1) = ""
            sourceRow = sourceRow + 1
        Next targetColumn
    Wend
End Sub
That will take each block of 10 data values in a column, transpose them into 10 columns in the next worksheet, then go to the next line and do the same till you run out of data.
samwichse is online now   Reply With Quote
Old 01-20-2012, 08:33 AM   #6 (permalink)
I can't that to do anything Sam I'm a total excel idiot
Old 01-20-2012, 08:38 AM   #7 (permalink)
samwichse's Avatar
Did you look in the next sheet over? Which excel version are you using? If your data is in worksheet 1, the output will be in worksheet 2.
EDIT: Check your gmail.
Also: go to "view macros," hit "options," and double check your keyboard shortcut is still there, mine disappeared after the edit. Set it to something like "ctrl+m" hit it once, and your data will be transposed into the next sheet.
Sam
Old 01-20-2012, 08:40 AM   #8 (permalink)
yep nothing can you send me a worksheet/book with it in and enabled/working then i can copy my data into your sheet 1 and press go.
Excels with macros might be blocked you may need to zip it up, nothing has come through yet.
Old 01-20-2012, 09:33 AM   #9 (permalink)
Got the macro going now thanks.
Old 01-20-2012, 01:42 PM   #10 (permalink)
AbCaRed00's Avatar
Good stuff. Played a bit with the old tables too. Curious how many rows are required for the data?
This below [done via spreadsheet to WP to spreadsheet again] can be pasted special as a formula into the B1 cell and should render 10 rows x10 columns if helps as an example.
=a1,=a2,=a3,=a4,=a5,=a6,=a7,=a8,=a9,=a10,
=a11,=a12,=a13,=a14,=a15,=a16,=a17,=a18,=a19,=a20,
=a21,=a22,=a23,=a24,=a25,=a26,=a27,=a28,=a29,=a30,
=a31,=a32,=a33,=a34,=a35,=a36,=a37,=a38,=a39,=a40,
=a41,=a42,=a43,=a44,=a45,=a46,=a47,=a48,=a49,=a50,
=a51,=a52,=a53,=a54,=a55,=a56,=a57,=a58,=a59,=a60,
=a61,=a62,=a63,=a64,=a65,=a66,=a67,=a68,=a69,=a70,
=a71,=a72,=a73,=a74,=a75,=a76,=a77,=a78,=a79,=a80,
=a81,=a82,=a83,=a84,=a85,=a86,=a87,=a88,=a89,=a90,
=a91,=a92,=a93,=a94,=a95,=a96,=a97,=a98,=a99,=a100 ,
