Originally Posted by HybridforCollege
Mind sharing some tips?
The best I got was 45-46 mpg, that was when I was driving 70-75 mph on a freeway for a long time, like 50 miles.
Usually I am only at 43, can't figure out how other ppl with the Insight are getting like 60mpg
Definitely follow Elucidus tips.
Also I try to keep my accelerations very sedate - around 1500 - 2000 rpm. My driving includes a good mixture of freeway and around town driving. I'm very new to hypermiling. I used to ride bicycle a lot and I now drive my Insight in the same way. Basically maintain your momentum, plan your changes in momentum way ahead. If you see cars breaking or a light changing to red, get off the gas and try to coast as long as possible. Find one of the mpg feedback indicators that you like the best and use that to train yourself to drive more calmly. Remember that the MPG reading you see on the indicator is optimistic by about 3mpg, so do what you can to raise that up and keep it up. So in a nut shell this is what I've learned to do so far:
1. Turn on the ECON mode and drive in "D" (not "S"). Use the ECON indicators to learn and improve your mpg driving habits.
2. From a dead stop, I don't step on the accelerator right away. I use the car's tendency to move when I'm off the break to start my acceleration. Then I gently add to the acceleration after the car starts to move. My acceleration to my driving speed is slow and steady, keeping my RPMs below 2000 and closer to 1500.
3. Plan ahead. Don't look at just the car in front of you, look at it and several cars ahead. If you see a lot of brake lights, let of the gas and hopefully you won't have to come to a complete stop. Try to drive a steady speed while the rest of the traffic is starting and stopping. Plan on lights changing way ahead too. If the light is red, try to adjust your approach to hit it when it goes green.
3. Look at your tire pressure. Mine was at 30 psi from the dealer. I recently increased it to 40 psi. This makes for a harder ride, but it will reduce your rolling resistance. I need to check into this more to see balance ride and shaking the car against the benefit of better gas mileage.
4. Read up on hypermiling on line. I personally try to practice good mph techniques, but try not to PO the people off behind and around me. Being aware means behind and to the side as well as in front of you. If no one is behind you, you can coast more and adjust your speed to increase your mpg.
Mostly you need to relax and be aware of the traffic pattern. Also, if you’re driving 70 mph and could be driving 60 mph, you're wasting a lot of gas.
FYI, the mileage I reported was with my AC turned on. I live in the Dallas area and AC is not an option for me in the summer months!
If I lived in L.A. with heavy traffic congestion and very aggressive freeway driving or a hilly location, I think that my mpg would be lower. So set reasonable mpg goals.
Hope this helps.
