Originally Posted by blueridge
nice.. can you give us more info on your 'hill techniques'.. as i live in western NC so all i got is hills/mtns.. i have been averaging about 47-48 total since i got the car.. my top was 56.1 on a 150 mile trip..
thx in advance..
Basically, the technique is similar to a rollercoaster ride, using the momentum going down the valley(s) to help climb the hill.
Try to gain speed prior to the hill without dipping into MPG too much. Let your speed drop as you climb the hill.
Example:
I see a 300 FT elevation change hill up ahead on the highway. Currently I am on a slight down grade. Instead of trying to max out MPG on the down grade. Use the grade to your advantage and speed up while still maintaining good MPG. Then as you climb hill let your speed drop.
At the bottom of the hill, speed may be 70MPH, and as you crest 55 MPH. You can let you speed drop more if no one is behind, otherwise I try to maintain a low end speed of 55 MPH to keep others happy and I stay in right lane.
I find that this can really help with the MPG. Routinely, 50 MPG going UP A HILL with this technique can be achieved.
If long climbs, you can negate a portion of the climb as well which helps with battery management.
I drive the same route every day, so I have managed to figure out most of the hills and the exact speed required at the bottom to climb them efficiently, so that helps as well. Knowing the terrain helps as well.
