Anyone else have struggle with keeping the speedometer green during acceleration? I've found that if I keep the rpm slightly above 1500rpm during acceleration the eco feedback (green light in the spedo) is easier to keep green. Once I get to 50mph, I can edge the rpm up a little more (just below 2000) and the car accelerates up to 60mph... eventually
I find it is easier to watch the tach than the blue/green lights.
I'm a teal accelerator, myself. I like to get the car up to speed as quickly as is reasonable and then coast/IMA propel the car.
If my memory is correct, I abandoned green acceleration about when I received my first trophy -as it seemed to be harder to achieve and didn't seem worth the effort (I'd rather be coasting with the ICE shut-off than slowly expending fuel over that same amount of time).
What level leaves are you?
JP
ps- wouldn't it be cool if the HUD's simple color changing arch were replaced with a color changing digital tach?
Oh we're still just beginners... we haven't even burned up the gas the dealership put in it yet! I think our leaves are three????
We still haven't got to the first trophy
I'm a total techie, and love all the gauges and displays. I use the Average and instantaneous MPG readout the most. It seems more forgiving than the blue/green light in the spedo.
I've learned you don't need to drive very carefully to get good mileage in this car. I have turned off the green/blue changey thing (found it really annoying) and rarely have Econ Mode turned on and I'm averaging about 46-48 MPG calculated (48-50 MPG on the MID). The only thing I did was to infalte my tires to between 38 and 40 psi, otherwise I drive pretty much like any other car, get up to speed with traffic and stay there - I do find myself coasting more often when I can.
2010 Insight EX - Tango Red Pearl
Former Cars:
2007 Honda Pilot EX 2WD
2005 Infiniti G35 Coupe
2003 Infiniti G35 Sedan
1999 Nissan Altima GXE
1989 Dodge Daytona (got as hand-me-down in 1998 )
I have found it is impractical to keep the car in the green when accelerating from a stop light with normal traffic. If the battery was bigger and you could apply more battery at lower RPM, then maybe you could do it. Instead, I do a brisk/firm acceleration to target speed and maintain that speed.
Its OK to go into the blue when accelerating. As others have said, you can still get 50+ MPG with normal types of acceleration. Only by accelerating at a glacial pace can it be achieved, and remember others are on the road with you.
Best way is to avoid stop and gos if you can. I use to go through 10 stoplights on the way home. I found another road that only has 3 and the mileage in the same. Sometimes it is not avoidable.
Reason: My grammar sux
I've been experimenting with combining the above two approaches. I do normal-with traffic acceleration up to about 30mph. I then become "slow" (but often not "slowest") traffic by reducing my rate of acceleration to 45-55 instant mpg on the slider. The car then creaps up to the 40-45 mph speed limit with-out hurting my mpg as much. Most of my trips are short ones, so this kind of thing is noticeable.
2010 Insight EX-Nav Clear Sky Blue. Driving the Blue Bird since May 30, 2009
First off, I keep pace of traffic. If allowed I accelerate til i hear that low groan from the hybrid system and ride it til the posted limit. I look at the indicator and use it as an aid in drafting.
After reading some of the posts here, I changed my acceleration style (I'm sure the people behind me appreciate that ) and have been accelerating briskly or with traffic, then once I approach my target speed; I back off and try to hold 50 or 55mpg. I haven't seen a big change in average MPG so it seems the acceleration from stop is a super critical component in average MPG. One thing I have started to notice is coasting makes a significant impact on average MPG. If I see a red light coming up, the further away from it I can start coasting, the better. It seems to really pull my average MPG up. Have I mentioned I really really like this car? I am constantly amazed by what it is capable of and what I can get it to do.
