Originally Posted by Zwolfe
You can overcome the recharge going up hills by applying more throttle. Well, of course ... d'oh, Zwolfe?
What I mean is that the battery charge needle will gradually go toward neutral (no charge, no assist) with the more throttle you apply. It will go to neutral with no drag from the IMA system if you apply enough throttle.
I noticed this from driving up mountains here in WV. Just trying to maintain speed pushes the IMA system to neutral until you crest the mountain (where regen is established once more).....
I took a look at this earlier today and I suspect that doing this just leads to longer or more battery recharging after you've crested the hill. Not certain though, but here is what I found.
1st hill. It is of moderate length but steep. On most days I can get to the top without forced regen if I have a strong enough battery charge and plenty of speed at the bottom. Today I had speed but weaker battery at bottom. Half way up forced regen kicked in. I stayed in D with Econ on, shifted the MID to energy flow screen, and gave it lots of throttle. The needle went from Chg to Asst, the speedo to purple. I let up slightly on the throttle, and the needle went back to Chg. I then pressed the throttle harder but the needle stayed in Chg. There was plenty of hill climbing power, and speed at the top. After the top, and during the following downgrade much more regen was needed to recharge the battery. ...I figure a net increase in amount of gasoline was needed to climb this hill.
2nd hill; This one is shorter but not as steep, the approach to the hill is such that I ordinarily need a short period of regen to get to the top. Today, after regen kicked in, I gently increased throttle while focusing on the needle and was able to get the needle to the mid point. At that point I was at the top of the hill and had to stop for a traffic light. After the light, is my usual recharge down grade followed by a gentle down slope where I ususally can get a good ev run. Today I couldn't clearly tell if additional regen was needed.
On the 1st hill I had the energy flow screen displayed. It appears that forced regen kicks in when battery charge level decreased to 1/3 of total capacity. Increasing throttle pressure, just after regen kicks in, just seems to dig deeper into the remaining stored power in the battery. Untill a safety something is encountered preventing further battery discharge and forcing the recharge process.
Regardless, it looks like applying more throttle may briefly delay recharge, but will do so at the cost of decreased mpg, and with the benefit of more speed while hill climbing. .....thanks very much for the suggestion
