Originally Posted by Eli
Dear Lord, please tell me you're doing oil analysis with drain intervals like that on your brand new car!
Well, as far as oil is concerned, I've followed the oil change estimates/warnings that the MID displays. Normally, I would change the oil every 3,000 on any car. The car is programmed to tell you when to change the oil as well as other maintenance intervals. I don't know what it's based on: mileage, cumulative engine revolutions, time, etc.
I'd be happy to change it more often if I knew I wasn't going to screw up the other maintenance interval warnings.
The other thing that makes me think that less frequent oil changes may be fine on this car is the fact that most of the time, it runs at fairly low RPM. Shifting into 'S' mode, the engine behaves like I would expect most other 4cyl cars to operate, between 2-3k RPM. In normal mode (drive), the car really does tend to drift down close to 1000 RPM. Of course, highway speeds are more like 2-3k RPM. So if in fact the engine is running fewer RPM, thereby less wear then wouldn't the need for refreshing the oil be less?
I did ask the dealer about doing more frequent oil changes and of course they were all for it. I didn't really get a straight answer though on how they handle the maintenance interval counter.
The paranoid hemisphere of my brain says, a car manufacturer would want people to do fewer oil changes (more wear) as part of planned obsolescence. On the other hand, I want to believe that Honda is a better car company than that.
Has anyone else with higher miles stuck strictly to the MID maintenance intervals?
I can't say enough good things about the car.
