Originally Posted by Mr 2011 Insight
... I hope to at least average 50 MPG after I get used to driving the car...
Not that I want to make it tough on you right up-front, but it might require some good hypermiling techniques to be in the 50's with your commute. One problem amongst other is the engine temperature. The I2 engine needs to be hot to creep up mpgs. The temp light (the blue one in your dashboard) will turn off at 125F, but still, the engine will not deliver high mpgs before it reach around 160F (measured with a SGII). It’s operating temps is between 178 and 184F. You need roughly a mile to get it to 160F. So one fifth of your commute is done with the engine “cold”. I don’t say it will be impossible for you to be in the 50’s, but you might need to work a bit harder with hypermiling techniques to get there.
To give you an idea, I have to go to 2 offices for my work. The first one is about 7 miles and I get about 50-51 mpg . It’s city driving (lights and 40mph roads). The second office is 28 miles away, highway driving. I get 60mpg in summer (53-54 in winter). I did recently changed the roads I take to get there, falling back on a long 45mph speed limit road with timed light. I believe I’ll creep out some more mpgs.
So my advice, for high mpgs, look for roads without traffic lights and use some pulse and glide techniques.
Oh…. Also, my tires are at 48psi.
Good luck and keep us posted on progress
