Need A Little Help with USB Audio - Page 2 - Insight Central: Honda Insight Forum
Old 05-29-2009, 05:24 PM   #11 (permalink)
Originally Posted by jonniedee View Post
No - I own a 6th gen iPod and it does many more functions than when i just plug in a folder'ed Flash drive. Just look in the owners manual...
I don't have my Insight or iPod yet (trying to decide between a 16GB Nano and a 120GB Classic).
Is there any functional difference between using either in the car with the non-Nav radio? I mean things like do you have to get the iPod out to turn it on/off when using it with the car or does it do all that through the radio controls?
What functions can the radio control (other than the basics like choosing an artist / album and track)?
Thanks!
OuttaSight is offline   Reply With Quote
Old 06-01-2009, 08:54 AM   #12 (permalink)
Ugh, how stupid can Honda be to not sort the Folders and Songs alphabetically? I mean that is just one of the dumbest oversights I've ever seen. And why on earth does it not use ID3 tags for song title - very stupid, too. It's not like MP3/WMA is new technology or something - these are super-basic functionality that should be in there and could easily be implemented in their software.
I really don't want to have to get an iPod - not only do I not like them, but then you have to charge it - with a usb drive there is not charging - just leave it plugged in 24/7 and it works!
2010 Insight EX - Tango Red Pearl
Former Cars:
2007 Honda Pilot EX 2WD
2005 Infiniti G35 Coupe
2003 Infiniti G35 Sedan
1999 Nissan Altima GXE
1989 Dodge Daytona (got as hand-me-down in 1998 )
CobaltDragon is offline   Reply With Quote
Old 06-23-2009, 05:58 PM   #13 (permalink)
Interesting thread; I'll be taking delivery of an I2 on Friday and was wondering how to set up my USB drive. I don't want to get an iPod either. Correct me if I'm wrong, it's a simple as copying my folders full of MP3 files to the USB stick and then plugging it in? The radio reads the folder names and when you select the folder it plays the contents? Man, this will beat the hell out of CDs...
dmanthree is offline   Reply With Quote
Old 06-24-2009, 10:11 AM   #14 (permalink)
Thanks!
Just be aware that the new 16gb Nanos are not supported through the USB interface.
Brian1 is offline   Reply With Quote
Old 06-24-2009, 07:07 PM   #15 (permalink)
Wrong! - I am using one just fine.
khollister is offline   Reply With Quote
Old 06-25-2009, 11:43 AM   #16 (permalink)
Really? That is interesting to know as they don't show that as one of the supported Ipods in the manual. Sorry to have given wrong info.
Old 07-05-2009, 11:08 AM   #17 (permalink)
Default Solution for the USB stick sort problem
Hi all,
This may fix the problem: FATsort
There is a version available for Linux (in Ubuntu just sudo apt-get install fatsort)
For Windows: FATSort
These programs are not the same. But they should work the same. These programs take the disk and resort so that everything is in placed in alphabetical order.
Both programs directly address the FAT tables. So use with caution! (make sure you have a backup of what's on the disk)
Instructions for Linux:
open a terminal
sudo umount /path/to_disk (i.e. /media/disk)
sudo fatsort -c /dev/disk (replace disk with the device i.e. /dev/sdb1)
The -c is to ignore the case of the files. To me that seems the preferred method.
Instructions for Windows, just see the website.
I just tried this under Linux and tested in our brand new Insight: it worked perfectly. I have the tracks numbered in the file name to make sure they end up in the right order.
AlbertW is offline   Reply With Quote
Old 07-10-2009, 02:13 PM   #18 (permalink)
Here's another sort utility that works on WinVista/7
FolderSort
Always back up your music before using a utility like this! Having said that, it worked fine on my 16 GB usb key.
Former Cars:
Old 07-10-2009, 02:17 PM   #19 (permalink)
wstander's Avatar
FolderSort
Just to clarify: Use this on the harddrive to sort the music first, then make the transfer to the USB? (After saving the backup, of course )
2010 Insight EX/NAVI Clear Sky Blue Metallic
ex- 2005 Prius Millennium Silver Metallic
pkg#6
ex-2004 Civic Hybrid Opal Silver Blue Metallic 5spd manual
ex- 29 other vehicles
Old 07-10-2009, 02:20 PM   #20 (permalink)
I actually just sorted the usb drive directly - I don't have any hard drives using FAT/FAT32 anymore - they are all NTFS.
Former Cars:
