Pictures of modified Insights - Page 9 - Insight Central: Honda Insight Forum
Old 08-29-2012, 01:23 PM   #81 (permalink)
Anyone here have Honda Insight 2012? because I've
amrizal is offline   Reply With Quote
Old 12-09-2012, 11:21 PM   #82 (permalink)
Default 2013 white on white
[IMG][/IMG]
biffaroony is offline   Reply With Quote
Old 12-10-2012, 09:28 AM   #83 (permalink)
wow ! thats NICE !
i wonder if the turn signal / fog light peice would fit in a 2010?? mabey a bit of cutting is instore for mine.
sfrsemurray is offline   Reply With Quote
Old 12-13-2012, 12:06 AM   #84 (permalink)
ski1297's Avatar
The wheels work great with the color!
2010 Honda Insight LX 35% tint
Eibach Pro Kit
15" Silver Enkei RPF1 with Michelin Hydroedge Green X
Mugen Zero Lift Body Kit / Mugen Ventilated Visors
Mugen Sport Exhaust / K&N Air Filter
Full Mugen Accessories
JDM Headlight Conversion HID/LED Upgrade
Delete Rear Wiper / Spray Nozzle / Shark Fin Antenna
***bags are for groceries***
ski1297 is offline   Reply With Quote
Old 02-23-2013, 06:04 AM   #85 (permalink)
Default My 2011 insight with takeda stage 2 pro dry s system
Hi greetings from malaysia
Fakhrins is offline   Reply With Quote
Old 02-23-2013, 10:35 AM   #86 (permalink)
Looks like you got an audio upgrade and some type of cold air intake or dry air intake?
Old 02-23-2013, 10:48 AM   #87 (permalink)
Nope, if the blue wire at the battery terminal u r referring to, its the pivot raisin volt stabiliser. I dont know why i have it on board. It doesnt help anything.
I have fitted a bigger ns60L battery instead of factory stock 40L. I need to hack off a bit of a bracket at the battery base to accomodate this bigger batt (since space have been taken by the air scoop)
And yeah, its a cold air intake meant for the crz, http://afepower.com/shop/details_new...5L&&brandID=78
I managed to get it in by swapping two holding brackets from crz. One is located above the radiator the second one is located at the cylinder head. In this photo im still using cable ties to hold the air scoop while waiting for the bracket to arrive.
I also noticed u have ultra racing bars installed on ur ride boss. U surely loved em. There is another chassis rigidity collar quite popular in malaysia and its not that expensive. Its a copy from spoon rigid collar but it work just as fine. I had it on my ride n the suspension works better.
Stiff Ring - Redefine Chassis Stability
If u wanna give it a try, i am sure i can help u out with the postage.
Old 02-23-2013, 02:56 PM   #88 (permalink)
Man, 400 bucks for the CAI? Interesting how it shifts the power band in the dyno chart.
Yes, I am sold on ultra racing bars, I got both strut and the B pillar one. Id like a few of the under body braces, but I am worried it would get hung up on stuff.
You notice any difference in mpg or performance with the CAI?
Old 02-27-2013, 09:15 AM   #89 (permalink)
Sharp, ATS*SOL. I've just picked up a 2010 I2 in black, and am looking for some touches to individualize it. Where did the chrome window trim come from? I've found lots of places offering the A/B/C pillar trim, but nothing for the 'outline', which is what I'm thinking of doing... Thanks for any guidance...
rallison is offline   Reply With Quote
Old 02-27-2013, 11:31 PM   #90 (permalink)
Originally Posted by Fakhrins View Post
And yeah, its a cold air intake meant for the crz, Cold Air Intake System Takeda Takeda Stage-2 Wrinkle Black PRO 5R Intake System; Honda CR-Z, 11-12 L4-1.5L TM-1016B-1 - aFe Power
Fakhrins,
Do you have a picture or part number for the brackets you needed? I can get aFe parts at a good price and this would be awesome to have.
Thank you
punksmurph is offline   Reply With Quote
