Problems with my new 35W DDM HID Lights. - Insight Central: Honda Insight Forum
Old 09-29-2010, 02:26 PM   #1 (permalink)
Default Problems with my new 35W DDM HID Lights.
My drivers side light intermittently would not fire up. when it did, it took longer than the passenger side to reach full brightness. So I checked connections, applied di electric grease to all connections and swapped locations of bulbs. The problem moved to my passenger side. I called DDM and they said I probably have a bad bulb and are sending me replacements.
However, I don't think that's the entire problem.
Now I either get the intermittent problem on the passenger side and or BOTH bulbs don't initially fire up. Now the misfires occur under the following circumstances.
1) When the ballasts haven't been used in several hours.(are cold) When things warm up, they fire up 100%. The kid at DDM said temperature has no effect on the ballasts. I'm by no means an expert but have my doubts.
2) When I start the car THEN turn on the lights. If I turn on the lights FIRST they seem to fire up every time.
For number 2, I speculate the cause may be the DRL's tapping power; so I disabled the DRLs by removing the 7.5A fuse. I'll see what effect that has.
Every time I call DDM customer service, I get some doofy kid that sounds unsure of himself and am not confident in the advice they are giving me.
I'm hoping to get better advice on here.
BTW, bumping the two headlamp fuses to 15A has had no effect and I reinstalled the 10A. I'm thinking I may have to use a relay harness but I shouldn't because its only a 35W Hid kit.
Old 09-29-2010, 04:44 PM   #2 (permalink)
Default Update
Disabling DRL's did not work; it's doing the same thing. Lights come on first time 100% when motor is off (when cold). I reinstalled 7.5A fuse.
Old 09-30-2010, 10:37 AM   #3 (permalink)
runtohel121's Avatar
sounds like you got faulty ballast
~2010 Honda Insight LX Atomic Blue - 2010-04-25~
~1,000 miles - 2010-07-13~
~10,000 miles - 2011-09-05~
~20,000 miles - 2012-05-22~
runtohel121 is offline   Reply With Quote
Old 09-30-2010, 06:24 PM   #4 (permalink)
Both of them?
Like I said, if I turn on the lights BEFORE starting the engine, they fire up every time. That makes me suspect that I'm not getting enough juice to fire off the ballasts with the engine running. Anyway, DDM is sending me new bulbs which I strongly suspect aren't the problem. Although it's weird that only one side was affected before I swapped the bulbs. The goofball " tech guy" at DDM said if the bulbs don't work, then" we'll take it from there".
Old 09-30-2010, 11:42 PM   #5 (permalink)
There is a reason I recommend the relay kit and there is another reason I quit posting to these HID threads......
Old 10-01-2010, 12:03 AM   #6 (permalink)
I respect your opinion. I'm probably going to end up using a relay kit.
Old 10-01-2010, 07:44 AM   #7 (permalink)
the relay kit is no sure fix. DDM just doesn't have very good quality control. I had the exact same issues as the OP. I ordered the relay, no change...still same problem. Went through two faulty bulbs/ballasts...gave up on DDM.
I know three others with the same issues with DDM kits...
2010 Insight EX - Tango Red Pearl
Former Cars:
2007 Honda Pilot EX 2WD
2005 Infiniti G35 Coupe
2003 Infiniti G35 Sedan
1999 Nissan Altima GXE
1989 Dodge Daytona (got as hand-me-down in 1998 )
CobaltDragon is offline   Reply With Quote
Old 10-01-2010, 09:33 AM   #8 (permalink)
Which brand HID kit did you finally go with?
Last night, I was searching for DDM Reviews and found most of them not to be favorable.......
Old 10-01-2010, 10:13 AM   #9 (permalink)
I use a vendor I met on a scion forum. His company is 3BSpec and Mike aka operatic is the person I deal with. He knows his stuff, he overnights his deliveries and is based in Texas. I have purchased 5 kits so far from him for my various cars. The only problem I had was a bi hid/halogen kit I purchased from him for an h4 lamp. I wanted halogen for low and hid for high. He said to reverse the wiring, however the bulbs light point is spaced differently so the light spreads over a different beam pattern. Granted that sounds great in theory, but it didnt work.
We should consdier getting him as an advertisier or vendor. I am emailing more info to that person.
3B Specialties
Old 10-01-2010, 11:21 AM   #10 (permalink)
Ditto. When I hooked up the Hellas to both my Hondas they functioned 100% better after I installed the relays.
