I got to look, but I am assuming the tube replaces the box and makes a right angle from the throttle plate area towards the frontof the car to the grill. I am out on the cold vs warm air intake. I have had mied results with my previous vehicles with removing the snorkle making it a cold to warm intake unless its below freezing out. Id entetained the idea of just buiying a cone filter and strapping it on to the throttle intake area and removing the filter box, but do not recall if there is any sensor that would need to be in the loop. If there is, those sensors need to be spaced a certain distance to get the a/f right.
As is the air filter element is about the size of 2 credit cards as far as the filter area. Not sure we would benefit from a larger surface area unless it had some induction involved.
