rain is here..messing my headlights - Insight Central: Honda Insight Forum
Old 10-08-2010, 03:56 AM   #1 (permalink)
Default rain is here..messing my headlights
its bin raining in socal, and my passenger headlight is getting wet from the inside
i dont think thats normal cause last year that didnt happend
what can i do to keep the inside dry!!!! im desperate...at this rate my headlight is going to get foggy from the inside and its going to look old
do i use a special product, or tape the edge, or wat !
Old 10-08-2010, 04:11 AM   #2 (permalink)
Seems like the seals might not be on properly. You can take apart the lights and use some strong silicone sealant or try and heat up the existing sealant to re-seat the seal. You can do this by removing the headlight and running a heat gun around the seal for a few minutes and then letting it cool and reinstalling.
One quick question, are you getting moisture in the lens or drops of water?
itwo is offline   Reply With Quote
Old 10-09-2010, 06:00 AM   #3 (permalink)
oh well i have a heat gun but idk how to take off the light or the bumper...
they charge 100 to take that off i rather look it up
mostly moisture (90% i think)
its been really cold so i think its the huminity
do you know how hot i have to go with the heat gun n for how long i should do it?
one more question sorry... where could i get a strong silicone?home depot maybe?
