take off front bumper? - Insight Central: Honda Insight Forum
Old 10-09-2010, 06:13 AM   #1 (permalink)
Default take off front bumper?
i need to take off the front bumper and the headlight so i can seal it with a heat gun ( it gets a lot of huminity form the inside )
anybody knows how to take off the bumper or the headlights?? thanks
i know cobb has done it ... id appretiate it if you help me out here please?
they charge 100 to take it off for me but i think its a simple task
Old 10-09-2010, 07:30 AM   #2 (permalink)
It looks pretty easy to me. If you look on the H & A or College Hills website or one of the many other websites that sell Insight accessories, look for the installation instructions for the fog light kit. Those instructions have the steps on removing the bumper and have a drawing of where the fasteners are located.
Old 10-09-2010, 10:52 PM   #3 (permalink)
Removing the bumper does wonders for the aerodynamics, oh wait, you are adding angel eyes, right?
I think Id talk to the dealer first if the lamp came unsealed. It maybe the seal around the base of the hids you installed.
Anyway, its fairly straight forward. Undo the plastic clips between the head lights on top and remove hte plastic strip. Then you can see down to the horn and front of the radiator.
Then remove the philips head screw in each wheel well facing forward of the car. Then down under the car undo a few more of those clips and philip head screws. Reach up and twist out the turn signal lights and fog lights. Then just gently peel away the edges from the fenders and the bumper should pop off. Make sure to lay a blanket in front of the car to rest it on.
Old 10-10-2010, 12:10 AM   #4 (permalink)
correct me if im wrong
first of all i need to remove the front grill cover ( it has 7 short clips )
next the other 2 clips under that
next remove the 6 clips that are under the bumper
next the single screw on each side of the bumper ( in front of the tires)
next pull the bumper carefully while its retained by 16 retaining tabs( 16 on each side )
and last disconnect the connnectors
is that it??
one more question . how do i take of the clips?? just tight and pull?
Old 10-10-2010, 12:17 AM   #5 (permalink)
oh well i bought the faily used headlight on ebay after i crashed n cracked the other one
or maybe i could go and say at the dealer hey how come this light is gettin moistured!! ( but not mentione the crash?? )
thatd be risky and they wuold end up charging me more i think
i checked the hid whole but it look normal
the moisture is actually on the other end right next to the grill
maybe the crack is open by there?
Old 10-10-2010, 12:46 AM   #6 (permalink)
Oh ok, I thought I recalled you recking your car. Interesting you would have that with a used part. Id look it over, may need a spot of super glue or somelens tape.
You can buy clear lens tape from kmart in the auto section. I got some to fix my cracked fog lamp.
Fixed lamp, notice slight sand paper pitted finish.
Supplies used in fix.
Before fix notice the blob of proxy I used that did not plug the leak.
Old 10-10-2010, 10:20 PM   #7 (permalink)
nice....
im going to work on my car all day tm since im off
hopefully i wont mess up .... my coworker said he doesnt have faith in me
any idea on how to take off the headlight??
i believe its only 2 screws but not sure... i dnt wanna be stuck tm
Old 10-10-2010, 10:29 PM   #8 (permalink)
Yeah, its not rocket surgery....
Old 10-10-2010, 11:19 PM   #9 (permalink)
one more question
the clips.... any technique you guys know i can use so i wont brake them
i heard there fragile
Old 10-11-2010, 10:49 PM   #10 (permalink)
I use a small flat screw driver to pop out the center, then use that piece to grab it out.
