Cargo area light bulb upgrade? - Insight Central: Honda Insight Forum
Old 12-17-2010, 10:07 PM   #1 (permalink)
Default Cargo area light bulb upgrade?
What size and type of LED bulb is best for this application?
Old 12-17-2010, 11:38 PM   #2 (permalink)
194 I got a 6 led one in white with the leds on one side since the bulgb sits vertically in the socket.
Old 12-18-2010, 07:19 PM   #3 (permalink)
WLED Miniature Wedge Base bulbs with High Power SMD LEDs
T3-1/4 (#194/16 type bulbs with High Power SMD. Wide Angle LEDs up to 120 degrees. 12 Volt DC operation.
Is this the description for the one you used?
Old 12-19-2010, 12:39 AM   #4 (permalink)
6 Ultra Bright S.M.T. L.E.D. T10 Wedge LED Light Bulb - Automotive LED Lights - LEDLight
Old 12-19-2010, 10:55 AM   #5 (permalink)
Thanks Cobb. I'm going to order one and give it a try. The stock bulb is just too dim for the cargo area.
Old 04-24-2011, 05:41 AM   #6 (permalink)
Hey dude, did this end up working for you? My IN2 doesn't come w/a trunk light (I'm from Malaysia)... so I'm lookin' @ installing one on my own.
infinitium is offline   Reply With Quote
Old 04-24-2011, 09:41 PM   #7 (permalink)
Ive seen many universal touch lights and cargo lights here in America. My first thought was to recommend buying the US lamp if you have a vent in the rear and swap it out.
Old 04-24-2011, 11:20 PM   #8 (permalink)
yeah, i have the same plastic placeholder on the left.. should be able to easily swap that out w/a proper US lamp.
Any idea where I could order one online and ship it over? (I tried using search terms "insight boot light", "insight boot lamp" etc but couldn't find any leads)...
Old 04-28-2011, 09:23 AM   #9 (permalink)
i got my boot lamp installed today... finally! went with a 12-LED set. fits snugly in the spot where the boot lamp should be. shines a brilliant whitish/blueish light:
I'll get more shots up @ nite one of these days... w/my SLR. Much easier to get an accurate idea of the light output
Old 04-28-2011, 09:56 AM   #10 (permalink)
Wow, looks oem. Does it work with the hatch or do you have a button somewhere? Like the 2 tone plastic trim, mines is all grey including the seats and carpet.
