Power Outlet - Insight Central: Honda Insight Forum
Old 01-01-2011, 10:29 PM   #1 (permalink)
Default Power Outlet
Is there a way I can get power to my power adapter (to charge a spare cell phone battery) when the car is not running. The outlet loses power when the key is not on. Thanks!!
moorea is offline   Reply With Quote
Old 01-02-2011, 12:44 PM   #2 (permalink)
The car doesn't have to be running but the key has to be in the ignition turned to allow power on.
Old 01-02-2011, 01:14 PM   #3 (permalink)
I should have been a little more clear. I would like power to the power adapter for when I turn my car off and go into a store or work.
Old 01-02-2011, 02:45 PM   #4 (permalink)
I don't know of any way to do that with the Insight.
Old 01-02-2011, 03:04 PM   #5 (permalink)
freezin4's Avatar
Go old school! Run a new fused line power source to your 12V power outlet from the constant power side of the ignition switch or the fuse panel.
Fine-Print Disclaimer PS: I am not responsible for your electrician skills (or their lack of), and catching your car on fire.
Good luck!
