Hello everyone,
Just picked up my 2011 Insight in Sky Blue Metallic..love the color
I installed an HID kit in my low beam with 10K color...nice blue to match with the car color. I also want to install a 3000K HID in place of the DRL. I bought the relay for this from the same guy but after I install it ..the msg "check DRL" appears when I start the car...and the HID lights don't come on at all
Does anybody on here know what's wrong or how to bypass this issue? Thanks!
The DRL is the high beam operated at a high frequency and 9 volts vs 12. You can buy an adapter to use your hids for DRLs from most HID vendors. The alternatice is to pull the DRL fuse, its 7.5 amps and behind the panel near the drivers side door or your knee.
Thanks Cobb,
That's what I thought...but maybe the relay that guy sold me is defective? Been calling him but he's not answering. I think I'm gonna call DDM Tuning people and get one from them. Hope it works.
I tried removing the DRL fuse but if I do that...then the light won't work at all..
You want to drive around with your high beam HIDs at full brightness all the time? The cars DRL system runs the halogen bulb at partial power to make it dim. The HIDs are either off or on, its difficult to regular their brightness. I just turned mines off by removing the fuse.
Cobb, any issues when you turn on your high beams? I got DDM HID 35W for my low beams and it takes a little bit of time for them to fire the first time.
Thanks Cobb I am going to pull the trigger and order the DDM kit with the relay like the one I have for my low beams but will go with 55w for the high beams.
________________________
2010 EX/Navi Clear Sky Blue
20% tint all around
Weathertech Floorliners
OEM Mud Flaps
17X7 MSW Wheels
205/45/17 Yokohama Avid Envigor Tires
Eibach Pro-Kit Lowering Springs
Alpine M-300 4 channel amp
Sound Ordnance 8" Amp/Sub
DDM 35W HID 6000K for low beams
Blacked out taillights and mirror markers
Direct Wired Escort 8500 X50 Radar
Shark Fin Roof Antenna
K&N drop in air filter
Insight badge removed
LED reading, dome and license plate lights
I gave a friend of mines a ride home and we tired them out. He referred to them as barn burners. He said if I got too close to an old barn the brightness would make the exterior ignight.
