Cheesie, the first few posts are kidding. Only problem Willie had was needed to replace the head gasket.
Many guys who go balls to the wall modding their car do have CEL lights that are on all the time, but still run fine. These have lots of boost, multiple turbo chargers if not a piggy back computer. Even if you throw a code, it wont stop your car from running., I threw an IMA light with my grid charger, but a second twist of the key turned it off and no code was recorded by the computer. Thats not going to stop me from condition/balancing my pack several times a year.
So.... What are your real plans that will throw codes or turn your car into a pool of liquid metal and smoking rubber? You replacing the engine? Adding 2 turb chargers and 30lbs of boost? Relacing the motor with 3 ima mothers sandwiched together?
So, I take it you want a CAI? I do too. I tried the warm air intake, removing the snorkle, blocking the vent to under the hood and every attempt to make the car breath warm air causes my mpg to go down and I seem to use more assist vs just motor. Seems our engines like cold air. I guess that makes sense with the compression rato to help reduce knock on pump gas.
