Camber kit??? - Insight Central: Honda Insight Forum
Old 01-18-2011, 03:39 PM   #1 (permalink)
Default Camber kit???
Hi everyone,
I just picked up a set of Tanabe DF210 lowering spring on Ebay for $120! yeah..what a steal should get it sometimes next week. The drop is 1.5in in front and 2.0in in the back. I'm afraid this drop will mess up the alignment....the camber in particular. I have the HR springs in my NSX and it really mess up the camber in the rear...making my tires worn out after about 15K miles...and the bad thing is I can't even find a camber kit for it.
I was wondering if any member has this spring installed and if I will need a camber kit to correct the alignment? Or if the camber kit even available for purchase?
Thanks all!
SkyBlu is offline   Reply With Quote
Old 01-19-2011, 12:22 AM   #2 (permalink)
I messaged this guy and he said they fit, Front Camber Bolts Alignment Kits 06 07 08 Honda Fit - eBay (item 250740999822 end time Jan-09-11 22:12:45 PST) I got them, havent gotton around to install them. I am in 3 degrees, but its still within spec.
Old 01-19-2011, 03:00 PM   #3 (permalink)
i lowered my I2 with tanabes too ( 1'' ) and i had to get the car realigned
i think i heard everytime you lower the car you have to realign it
but i thout the carber kit was only for coilover
coilover bend in the tires when you lower the car and some guy at the shop told me the camber kit was only for keeping the tires from bendin in, like still stayin straight just like as using lowering springs
Old 01-20-2011, 12:08 AM   #4 (permalink)
When you lower most cars you throw off the toe and camber. The toe is the most important. Camber is next. Since I got new tires I wanted to make sure I had it right or best I could. 3 degrees is still within spec for camber, but toe is suppose to be at zero.
Old 01-20-2011, 11:39 PM   #5 (permalink)
BlueIMA's Avatar
My Eibach springs only lowered mine 1" and upon checking alignment everything came in spec to include the camber.
________________________
2010 EX/Navi Clear Sky Blue
20% tint all around
Weathertech Floorliners
OEM Mud Flaps
17X7 MSW Wheels
205/45/17 Yokohama Avid Envigor Tires
Eibach Pro-Kit Lowering Springs
Alpine M-300 4 channel amp
Sound Ordnance 8" Amp/Sub
DDM 35W HID 6000K for low beams
Blacked out taillights and mirror markers
Direct Wired Escort 8500 X50 Radar
Shark Fin Roof Antenna
K&N drop in air filter
Insight badge removed
LED reading, dome and license plate lights
BlueIMA is offline   Reply With Quote
Old 01-22-2011, 12:35 AM   #6 (permalink)
Great..thanks Cobb. I'll check it out. What about the kit for the rear tires? You said your camber is in 3 degree but it's still within specs? Is it on both front and rear? I thought that would be out of specs... Do you notice any uneven wear on your tires? Like more on the inside? My Tanabe DF210 will drop my car 2 inches in the rear and 1.5 inches in the front. Anyhow, I think I will get the car alignment checked after the springs are installed.
Old 01-22-2011, 11:30 PM   #7 (permalink)
Since we use a trailling arm there is no adjustment and the rear was fine, just the front was tilted in a few degrees at the top. No uneven tire wear and thats running 44psi too.
Old 01-23-2011, 12:47 AM   #8 (permalink)
hey cobb i dont really know bout the toe and the camber
do you think i messed up on what i got?
i lowered my car 1'' and i have some 17''s
they stuck out a little so i rolled the fenders
am i gonna hurt the carmber or toe with these rims of mine?
Old 01-23-2011, 10:18 PM   #9 (permalink)
No. Maybe I got the DF vs NFs?
Old 01-25-2011, 04:13 AM   #10 (permalink)
i got the ones you got
