Fit suspension on Insight - Insight Central: Honda Insight Forum
Old 01-24-2011, 04:41 PM   #1 (permalink)
Default Fit suspension on Insight
anyone know if you can install 2010 honda fit lowering springs to an insight?
I am assuming yes but wanted to see anyone else knew.
usc_insight is offline   Reply With Quote
Old 01-24-2011, 11:37 PM   #2 (permalink)
Anything is possible, what are you trying to do? A lot of the parts are a direct fit, just because you can doesnt mean it may improve your performance. A few people can agree the sway bar is a direct swap. Ive been tempted to try the coil overs, but they will need some adjustment to make up for the weight bias.
The Insight is a few hundred pounds heavier and balanced differently than the fit. Are you getting a deal, you want more of a drop? Are they from an 09?
Old 02-03-2011, 06:34 PM   #3 (permalink)
I would like to go lower and there are more options for less expensive suspension options with the fit, ie coil overs - that's why!
Old 02-07-2011, 12:30 AM   #4 (permalink)
Id suggest coil overs. Those you can adjust the rear to make up for the weight difference. Nothings more fun than to drag the tow hook thingie on the ground...Good thing the muffler is tucked up under the bumper.
Old 02-08-2011, 04:12 PM   #5 (permalink)
I'd kinda like to put a rice burner 4" stainless exhaust on mine.
Old 02-09-2011, 12:24 AM   #6 (permalink)
Go for it. You got to adopt a 1 1/2 inch pipe on up to that dia.
Old 02-09-2011, 03:21 PM   #7 (permalink)
I want to make my turn signals blink really fast too!
Old 02-09-2011, 11:46 PM   #8 (permalink)
Just get yourself a set of led bulbs from ebay. You not going with clear corners?
