Civic blue courtesy lights - Insight Central: Honda Insight Forum
Old 01-29-2011, 09:05 PM   #1 (permalink)
Default Civic blue courtesy lights
I am wondering if the blue courtesy lights for an 08 Civic would work on an 10 Insight? In particular I am wondering if the on/off switch will fit in one of the slot under the ECON button.
wjpm is offline   Reply With Quote
Old 01-30-2011, 10:27 PM   #2 (permalink)
I believe Liberal Guy has already done this. I know we share a lot with the Fit, but I am sure it wont be too much different for something like that. I just got 2 led lamps at walmart, an add a circuit fuse holder for the accessory fuse and wired mines up to that. They are always on with the key.
