Its not the grade, but the tier. With top tier you can get triple digits, LOL. Just kidding. Now ethanol content does play a role. Washing your gas helps to remove that.
If its knocking and retarding the timing case of gas grade, then going up a grade will help. Ive tried mid and preminum. I want to think with mid grade it kept the rpms lower when accelerating. With preminum I saw or could tell no effect.
