Grid charging and balancing the I2
After reading about the wonders grid charging and balancing the pack can do on the other forums I decided to give it a try. My I2 was having a lot of regens and useless in many cases. I decided to give it a try. I found someone to build one and bought it. Doing this will likely void you warranty and can be dangerous.
To access the hybrid battery you need to remove the rear flap, tire, foam insert, spare tire holder, then metal shield. The spare tire holder ie held in with 12 mm bolts. You will need to fold down the back seat and kock off the plastic cover to access them. Lift that point upwards, then lift out.
The metal shield uses a few torex screws and 10 mm bolts. There is one inside the lid area where the master switch is and move it forward to turn it off for good. Then remove the 2 plugs in the bottom.
Removed junk.
Hybrid battery. Thats just the case, the actual battery is smaller. This included some controllers and some other things than just the sticks that make up the battery.
Connections.
Those 4 bolts next to the switch are hot when the switch and key are on. The front ones are positive, rear negative.
Lay out.
So, when charging I use a 12 volt battery charger to keep the 12 volt side good and use a voltage meter to measure progress. Yes, I have a second battery in the trunk for the 12 volt side for the amp and subs.
