question bout rims.. - Insight Central: Honda Insight Forum
Old 03-15-2011, 11:36 PM   #1 (permalink)
Default question bout rims..
whats the gray sticker things inside my rims??
everytime i get a tire rotation they change this things around
http://www.insightcentral.net/forums...8-img-1809.jpg
Old 03-16-2011, 01:40 AM   #2 (permalink)
Those are weights. They are used to balance the wheels. In the old days, they would hammer a piece of lead into the edge of the rim. With the expensive and fragile rims of today, most people just use these stick on weights.
Old 03-16-2011, 01:54 AM   #3 (permalink)
I would imagine they could stick the weights further back on the hoop so that you can't see it as easily from the front. Not sure if it needs to be centered with the mounting pad but I would think they could at least move it further into the wheel
pro-touringAK is offline   Reply With Quote
Old 03-16-2011, 06:38 PM   #4 (permalink)
yeah i wanna paint them black since they are notisable
the front one only has like 1 or 2 left
is that bad??
Old 03-16-2011, 07:19 PM   #5 (permalink)
ghammerly's Avatar
They are used to balance the wheel/tire combo. A new tire will change how many and where the weights are placed in order to get the tire balanced. You don't want teeth rattling shaky tires eh?
The old adhesive can be removed with some Goofoff or some adhesive remover.
ghammerly is offline   Reply With Quote
Old 03-16-2011, 08:25 PM   #6 (permalink)
It's okay to paint them. I would remove the goo on the ones without lead first.
