looks like the coilover system from Yeloow. specs as follows:
YELLOW SPEED RACING 2010+ Honda Insight DPS Coilover System
Dynamic Pro Sport Full Adjustable Coilover Suspension Kit
MSRP: $1350.00 USD
Spring Rates: 6kg front, 4kg rear
FEATURES
33 levels of adjustable damping
Made from high quality 6061 aluminum with T6 for increased hardness
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillowball top mount with adjustable camber (not available for some models)
Monotube high pressure design reduces oil leakage
Electroplated body for protection from corrosion and rust
CONTENTS
Set of four coilovers: front left, front right, rear left, and rear right
Spanning adjustment wrenches
Dampening adjustment keys
PRODUCT DESCRIPTION
The DPS coilover system is a 33 way damper and rebound adjustable monotube full coilover system. The setup has separate height and pre-load adjustments allowing for optimal adjustment and allowing full strut travel at all times. Pillowball upper mounts and top mounts are constructed of 6061 powder coated aluminum. Threads are teflon coated to prevent rust. Rebuildable and serviceable in the US.
currently for sale on ebay:
YELLOW DPS COILOVER 2010+ HONDA INSIGHT SUSPENSION SET - eBay (item 190504820017 end time Feb-27-11 03:03:17 PST)
