Our ima battery only holds .5 kilowatts. I can cause a negative recal by ust turning on both defrosters. Rain makes it harder for the car to move both the rotation of the tires and wheels as well as the hole it punches through the air.
Unless it throws a code, you may want to hook up with willie and see if he will help you balance your pack. Id wait til the weather clears since this is when it first started.
