1 Bolt Netbook Mount - Insight Central: Honda Insight Forum
Old 04-02-2011, 01:53 PM   #1 (permalink)
Default 1 Bolt Netbook Mount
Take the Bolt out of the Left Front base of the Passenger's Seat,
Replace it with a Longer one.
I used 3 Washers under the Flange to Space it out Flat.
You Need to come up @ a 45 degree angle or
You will Block the Head of the Bolt You need to Tighten.
I Used 3/4" Pipe. Enlarge Hole in Flange for Bolt.
2 90s above the 45 will allow you to stay close to the console.
I Prefer The Netbook Tray @ 45 degrees instead of Flat.
StarFish is offline   Reply With Quote
Old 04-03-2011, 07:36 AM   #2 (permalink)
That's great. Now you won't be bored driving down the roads.
Old 04-03-2011, 08:34 AM   #3 (permalink)
One suggestion. Run the wires down the inside of the pipe. You can drill holes near the bottom to run the wires out. That will make it look nice and neat.
Southern Dad is offline   Reply With Quote
Old 04-03-2011, 03:44 PM   #4 (permalink)
Looks like a real quality item there, Clark.
