Originally Posted by Awbarnf
I figured out the Accord horn install! The horn has a tuning screw that needs to be loosened to determine the desired sound. You also need to make sure the horn is securely mounted for it to be grounded since the stock plug has one wire. Now our Insight will wake the neighbors!
can you please post a video of how it sounds after you adjusted it properly. i think i want to go the honda accord horn route vs. some aftermarket nonsense.
