Exterior LED bulbs - Insight Central: Honda Insight Forum
Old 06-22-2011, 05:46 PM   #1 (permalink)
Default Exterior LED bulbs
I'd like to replace the following halogen bulbs with LED's
BACK-UP LIGHT (921)
LICENSE PLATE (16
FRONT & REAR TURN SIGNAL (992 / 7440A)
Question: who sells the above LED bulbs guaranteed to fit a 2010 Insight?
Do I get clear or color bulbs?
And is there some kind of attachment for the turn signal bulbs to keep them from flashing fast?
Thanks
wjpm is offline   Reply With Quote
Old 06-23-2011, 12:06 AM   #2 (permalink)
I use bulbs from superbrightleds.com
You not replacing the 194 bulbs that are used in the side markers or the city lights? What about the 194 in the glove box, hatch lamp or the festoon bulbs in the dome and map lights?
Old 06-23-2011, 01:54 AM   #3 (permalink)
i wanna change all the lights inside the car but idk how to take off the cover from the ones over head
any advice?
Old 07-06-2011, 12:50 AM   #4 (permalink)
Its very similar to what I tell my girl friend to do every so often. Grab, squeeze and pull.
The map lights you need to pry the lens down near the center part where they meet and carefully pull the outer edge out. For the dome light you got to get a small blade screw driver or knife and carefully pry it off.
Old 07-07-2011, 03:04 AM   #5 (permalink)
whats the size of the bulbs?
same as the city light ones? 194?
Old 07-11-2011, 08:43 PM   #6 (permalink)
ATS*SOL's Avatar
vleds.com i use them on all my cars but ive heard good things about superbrightleds.com
* ATSxDPK * Wek'Sos Industries * Franklin Autobody * RyWire * Prestigious MotorWorks * All Star Detailing * R.A.W Spec Wheels * F.C.B. * N1 Concepts *
ATS*SOL is offline   Reply With Quote
