wheres the turbo kit? - Insight Central: Honda Insight Forum
Old 06-23-2011, 02:33 AM   #1 (permalink)
Default wheres the turbo kit?
theres a link to a turbo kit for the I2
i cant find it... has anybody seen it around?
or know any links to more performance for the I2?
Old 06-25-2011, 01:06 AM   #2 (permalink)
ski1297's Avatar
Could not find info on a turbo kit. But I did find this supercharger! Rotrex A/S
2010 Honda Insight LX 35% tint K&N Air Filter
Eibach Pro Kit
15" Silver Enkei RPF1 with Michelin Hydroedge Green X
Mugen Zero Lift Body Kit / Mugen Ventilated Visors
Mugen Sport Exhaust
JDM Headlight Conversion HID/LED Upgrade
Delete Rear Wiper / Spray Nozzle
Shark Fin Antenna
***bags are for groceries***
ski1297 is offline   Reply With Quote
Old 07-06-2011, 12:57 AM   #3 (permalink)
Id look for a fit or crz kit. Most performance shops can make something for you.
Old 07-07-2011, 03:08 AM   #4 (permalink)
when i asked for the price for this kit, they said 3000 for stage 1 and 4500 for stage 2
this is the kit i was looking for, i forgot it was a super charger, not a turbo
idk the difference anyways other thn they = more hp
i think cobb said he was looking for a kit
have you found one yet?
i wouldnt like to get a custom made one from a shop
maybe there not that safe? idk really but id really like one
Old 07-07-2011, 10:44 AM   #5 (permalink)
Holy crap, thats for the I2. Id go for it. Super has less plumbing than the turbo. Make sure to get it tuned. They may need to turn off the ima system to get an accurate tune.
Old 07-07-2011, 11:46 AM   #6 (permalink)
Super Charger and Turbo Chargers are different. I know the answer, but I can't explain it very well.
Insightlover2011 is offline   Reply With Quote
Old 07-07-2011, 11:57 AM   #7 (permalink)
The difference is when the power comes in. A super its on tap at any rpms. The turbo it comes in as the car is under a load and as rpms climb, With compound turbo setups and those with variable geometry this lag has been removed, but is that what your kit would contain?
Id go with a super myself. Since I got the phev kit I am happy and really not in the market for forced induction.
Old 07-07-2011, 01:10 PM   #8 (permalink)
I hear that superchargers are powered by the battery, whereas turbochargers are powered by exhaust pressure. Hence turbochargers require high revs to build up that exhaust pressure to drive its turbine, but advantage being that the pressure is more or less free.
carniver is offline   Reply With Quote
Old 07-07-2011, 03:27 PM   #9 (permalink)
Zwolfe's Avatar
Typical dyno results for a supercharger show a smooth power curve throughout the power band.
Turbochargers typically show increased results the higher the RPM is.
One thing people often complain about turbochargers are that they have 'lag,' and this is one reason why there are twin-turbochargers to help remedy the problem.
Some people slap on a huge single turbocharger and have tremendous performance results (assuming it has been tuned appropriately) in the upper RPM power band, however, putting around from here and there (i.e. around town) it's not uncommon to hear of these people complaining about lag.
However, superchargers are not without fault. Superchargers are just an extra accessory that needs turned by the engine. However, considering they provide additional HP, smoothly throughout the RPM band, it's essentially irrelevant. The point is, turbochargers don't need cranked by an engine.
It's basically a pick your favorite poison sort of thing.
Old 07-07-2011, 10:44 PM   #10 (permalink)
ski1297's Avatar
I would love to see someone add the Rotrex to a Insight.
Eibach Pro Kit
Mugen Sport Exhaust
Shark Fin Antenna
