what is really a camber kit?? - Insight Central: Honda Insight Forum
Old 07-07-2011, 03:26 AM   #1 (permalink)
Default what is really a camber kit??
i got some problems with my aligment and not knowing bout camber kits makes it difficult to know what im doing to my I2
ive been looking around but im not really sure if im right
correct me if im wrong
1. only needed if got coilovers
2. the I2 doesnt have them, they are optional?
3. they keep the tires straight after messing with the height of the car
4. even if you have them, still have to align the car after lowerin or lifting
help please
Old 07-07-2011, 10:38 AM   #2 (permalink)
3 and 4 are correct.
1 not always true, depends on how much you drop the car.
2, no, they did not make them when I looked for it, but I got the Fit kit.
Old 07-07-2011, 03:24 PM   #3 (permalink)
I lowered it just an inch
Few more questions...
1 Do camber kits keep the aligment longer? Meaning you dont have to worry bout the aligment as often??
2 do all cars have this this named camber? Is this different from the camber kit?
Lastly
Cobb can you send me a link to the camber kit you got on ebay??
I wanna get a kit also, if it will really help my car
Old 07-07-2011, 08:39 PM   #4 (permalink)
ghammerly's Avatar
Your camber is not going to change enough to worry with a one inch drop.
I would take it to the alignment shop and have them check the toe since most cars have some bump steer as the suspension departs from normal ride height. On the gen one and two Insights the front suspension is McPerson= very little camber change with ride height change.
The rear is twist beam and it has no camber or toe change with ride height change.
Cars with double wishbone suspensions such as Miatas or second generation CRX are very sensitive to ride height= big camber change.
ghammerly is offline   Reply With Quote
Old 07-12-2011, 01:29 AM   #5 (permalink)
cheesie, you should ask these stores these questions.
Long story short, camber means you are wearing the side of your tire vs middle. I am running -2 degrees and my tires wear evenly. I also rotate my tires.
The rear of your car will likely never have a camber issue unless you wreck it or curb the rear some how. So, by putting tires on the rear they get evened out again from the front.
As far as tread being worn evenly down the middle I have seen that when tires are inflate to like 80psi. Lowring the psi will fix the issue.
Old 07-12-2011, 05:28 AM   #6 (permalink)
ATS*SOL's Avatar
im assuming your toe is also correct
* ATSxDPK * Wek'Sos Industries * Franklin Autobody * RyWire * Prestigious MotorWorks * All Star Detailing * R.A.W Spec Wheels * F.C.B. * N1 Concepts *
ATS*SOL is offline   Reply With Quote
Old 07-14-2011, 12:44 AM   #7 (permalink)
Yes, I got it set to zero. Adjusting the camber or any setting would almost always require readjusting of the toe.
Old 07-15-2011, 02:37 AM   #8 (permalink)
well at least the guy at the shop said one thing true: only the front tires can get aligned
everything else he said i think he lied
everywhere i go i feel like i get lied at and i cant really argue cause i know nothing bout my car
but in bout a month ill start going to college again and ill be taking an auto course
im tired of mechanics stealing from people like me
Old 07-17-2011, 01:25 AM   #9 (permalink)
Yeah, they will do that. Best to get a quote and get a second opinion, ask a friend or post here.
I like the guy who tried to sell me nitrogen for my tires. I told him I rather have hellium so they would be lighter weight. He argue the point. So, I asked if my mpg didnt change, could I get a refund and he could take his air back, I would use regular air from the atmoshere.
He said no.
