Tanabe Install - Insight Central: Honda Insight Forum
Old 07-17-2011, 07:43 PM   #1 (permalink)
Default Tanabe Install
Hey,
I recently bought some NF210s and have been debating about doing the install myself. I decided to get a few price quotes to see what it would charge to have a shop install them. I was quoted $240 + $60 alignment up to $500 for install and alignment. I felt pretty comfortable with the $300 guy but my question is, it cant really be worth $300 can it? Does anyone have an links to a self install? I figure its 3 bolts on the top and 2 on the bottom to take off the strut and have a shop with a compressor replace the spring and then bolt it right back in? Anyways, any feedback would be appreciated.
(EDITED)
So I went for an oil change and talked to the mechanic about the future plans for the car and he said he would put the springs in for $100 so I took him up on the offer. Now I just need some wheels and rubber for it! Anyways I added some pictures and measurements of what it looks like after if anyone is interested. The ride height of the car is 7.5" down the rail so it did a perfect job at leveling it out.
FRONT
FRONT
REAR
REAR
2010 Honda Insight: Tanabe NF210 Springs, 30% Window Tint, K&N, Flip Keys, Accord Horn, HIDs, Dynamat 4 doors, hood and trunk
RedrumedInsight is offline   Reply With Quote
Old 07-17-2011, 09:36 PM   #2 (permalink)
its just like another othert spring install. If you shoot me your number Ill talk you through it.
Basically renta spring compressor from any auto store. You need a long handle 17 mm wrench to get the top nut on the front struts, then undo the sway bar link and lower control arm bolts. Make sure you get them tight when installing or they will knock.
The rear you need to jack the rear wheels off the ground and support the car where the jack where normally go. Then undo the lower shock bolt and watch out as the bar will swing down.Then grab out the old springs, put in the new and reattach the shock bolts.
Id drive it 2 weeks then get the alignment, your toe should of off a few degrees and zeroed out.
Old 08-23-2011, 02:17 AM   #3 (permalink)
Stone's Avatar
So how does you I2 feel withe NF210s installed, I'm on the verge of picking up the NF210s, but I'm considering the Df210s. Can't decide if I'd I need that much drop, so I'm curious about how they are treating you.
2010 I2 EX Crystal Black ~ Alpine iDA-X305SBT w/KTP-445 power pack ~ Infinity 6030cs & 6032cf ~ JL Audio 500.1 amp/JL 10" W3 w/custom box ~ 35% 3M ceramic tint ~ blue interior LEDs ~ deleted rear wiper ~ K&N Filter ~ Shark Fin antena ~ Accord Horn ~
Stone is offline   Reply With Quote
Old 08-24-2011, 06:47 PM   #4 (permalink)
I'd go low or go home if you are after mpg. Just remember the lower it is the less suspension travel you have.
