Keep in mind the hybrid battery and system doubles as your alternator. So, the car uses what it considered excess power from the gas motor to keep that topped off for use. Unlike the prius we have a meter to tell us how much of the power is going where. The prius does something similar when its gas motor is in use and the battery is low.
Also, the meter that shows the battery capacity is delayed. Its usually lower than what it shows.
For the most part, that is "normal".
