Which battery color should I pick? - Insight Central: Honda Insight Forum
Old 08-07-2011, 11:52 PM   #1 (permalink)
Smile Which battery color should I pick?
I am leaning towards red since the car is red. 14 of these sticks in the i2, right? Man, thats a lot of weight in batteries. These sticks must weight 5 lbs each.
Old 08-08-2011, 06:50 AM   #2 (permalink)
What color is the battery case that they go in?
Old 08-08-2011, 11:37 AM   #3 (permalink)
It's black.
Old 08-08-2011, 06:43 PM   #4 (permalink)
It's just shrink wrap, right?
A solid color is boring.
I think you should go for a checkerboard pattern. Do them all in white and cut 1 inch strips of black shrink wrap and space them in a 1 inch stagger.
Old 08-12-2011, 02:04 PM   #5 (permalink)
Vendor
I2 has 7 of the double sticks (at 4.8 lbs), so you've got green/orange. The single sticks are Gen-I and are 2.4lbs each.
Old 08-12-2011, 07:46 PM   #6 (permalink)
You have already begun rebuilding packs for the i2? Please give us the details and if the "betterbattery" is available?
Old 08-14-2011, 12:48 PM   #7 (permalink)
Vendor
We've been rebuilding Gen-II batteries for years now (where do you think your sample battery came from?).
We will have a BetterBattery available for Gen-II cars toward the end of the year. There are some engineering changes to make them. Right now there isn't that much call for them (maybe one 2006+ Civic per month). We have yet to get an I2 or CRZ customer, but the cells are the same as the 2006+ Civic, so the BetterBattery packs will be available (and the price is based on the number of cells, so the I2 will be cheaper than the I1).
Old 08-14-2011, 03:17 PM   #8 (permalink)
webskipper's Avatar
Stock cell capacity 6500 mAh
BetterBattery 8000 mAh
Ron says they are lighter, less internal resistance, and therefore run cooler.
Hmmm 23% improvement and 5F cooler, and I get a chance to hyper-mileage better than new?
Dear Santa....
2000 Insight #5488 AC MT
251000 Miles
Best Tank 875
Best1Way 119.1
webskipper is offline   Reply With Quote
Old 08-15-2011, 05:02 PM   #9 (permalink)
Vendor
Dear Santa....
Not lighter. Sorry. The same 2.4 lbs per stick.
Old 08-16-2011, 06:57 PM   #10 (permalink)
Velociraptor's Avatar
What is all this about mAh and weight?? --- this thread is about Color. The man wants some automotive sartorial advice!
Velociraptor is offline   Reply With Quote
