I am leaning towards stupid myself. Granted the oem hybrid pack holds just a tad over 500 watts and when its used to power both defrosters, lights, etc you are sucking it dry.
I think you should start with lessen your 12 volt loads like replacing all lamps you can with leds, your halogen with hid. Then roll down the windows or use the lowest blower speed possible for the HVAC.
