Satellite Antenna Wire Install
Posting this because I couldn't find an answer myself
After some debate on where and how to install a satellite radio antenna, I founda good spot was through the front passenger side tweeter
Pop open the glovebox (search in the forums for info)
Next, get yourself some type of plastic flat edge. I used a flathead screwdriver and scratched up the dash some. A plastic spakle knife (drywall section at your local hardware store) would have been perfect. It's tight to pop out the tweeter cover. It's much like taking off the piece the power adapter is hooked to.
Slide the tweeter out of the way and when you look under the glovebox you will see daylight. There is plenty of hand room to work with too. I left just enough wire out that the antenna sits in place because the tweeter cover is holding the wire in place.
Run the antenna behind the console to wherever your receiver is and its done.
