Bumper - Insight Central: Honda Insight Forum
Old 10-24-2011, 10:16 PM   #1 (permalink)
Default Bumper
I have the 2010 insight EX and today I accidentally hit my bumper while coming up a drive way, does anyone know how much, and where I can get a new official Honda bumper? I went to Honda parts now, and they have what I need but they do not specify what color you need. Does anyone know the reason why? I need part #1 on this website. Thanks!
Part Detail
Haliaka18 is offline   Reply With Quote
Old 10-24-2011, 11:55 PM   #2 (permalink)
Part Detail
I highly doubt the new honda bumper would come painted, new parts like that rarely do. You could get a used one on ebay probably for cheap and have it painted to match your car color.
Here are a few....
http://www.ebay.com/itm/10-11-honda-...item3f09258832
http://www.ebay.com/itm/HONDA-INSIGH...item3a666b262f
2010 Tango Red Pearl Honda Insight EX
Purchased certified used 07/2011 for $16700 OTD
Stuff I added
Advent Hands-free Bluetooth System
Magnet Bra
Stuff that was already installed by previous owner
Carpet floor mats
Cargo cover
Cargo Tray
Door Visors
Door Edge Film
Honda pin stripe
Splash Guards
Body side molding(painted silver to match grille)
Fog lights
Wheel locks
Rear bumper applique
Tinted windows
Honda Valve caps
Honda license plate bolts
vegajf51 is offline   Reply With Quote
Old 10-25-2011, 01:49 AM   #3 (permalink)
Bumpers come primed not painted (shipping is VERY expensive) ... also you'll have better luck getting your answers regarding your MY Insight on the other site as this one is for MY 2000 - 2006
Old 10-25-2011, 03:17 AM   #4 (permalink)
It is the work for a body shop
It is actually a bumper cover and is often repaired by a body shop depending on the damage. I think most body shops use remanufactured bumper covers if the damage is severe and they cannot repair it in the shop themselves, but they still have to paint it.
Red 2000 MT #1498
2003 HCH CVT
kennysmith is offline   Reply With Quote
Old 10-26-2011, 01:46 PM   #5 (permalink)
InsightfulMeasures's Avatar
The majority of vendors will sell the bumpers sans the paint. With that said, hondapartsnow.com has the best prices for a replacement bumper that I found thus far.
Good luck with the parts search!
"It's actually very difficult to make something both simple and good" -Paul Simon
InsightfulMeasures is offline   Reply With Quote
Old 10-27-2011, 02:01 PM   #6 (permalink)
I've put in the request to have your thread moved to the 2nd Gen forum as its currently in the 1st Gen forum. You'll likely get a better/quicker answer there.
Usually many of us in the US source parts from Majestic Honda - The Internet's #1 Honda Automotive Parts Store
Not sure where you are.
Old 11-25-2011, 03:33 PM   #7 (permalink)
Default how bad is it?
If there isn't a crack, you can repair it yourself. My wife backed into my car two weeks after buying it. It left gouges in the plastic but no crack. I took some body filler and slowly filled it then sanded smooth. Once smooth apply a quality adhesion promoter and primer. If needed sand smooth. I used dupont hot hues paint and clear for paint. Apply 2-4 coats of base coat and then clear. You will probably get a run or two. No prob. simply let it dry and come back with wet sand paper (1000 grit or more) and then polish with polishing compound. A quality paint store can also put the primer, paint and clear in a can that will mix the hardner in when needed.
Hope that helps
Brian
pro-touringAK is offline   Reply With Quote
