what kind of oil for the I2 - Insight Central: Honda Insight Forum
Old 10-28-2011, 02:38 AM   #1 (permalink)
Default what kind of oil for the I2
so im taking an auto class and next week im taking my car in to the shop so i learn how to do an oil change.... finally
hopefully the transmission oil too, since i always hear its really easy, but always too expensive at the dearlers
i need to buy the oil im gonna use on my I2 but idk what kind i need
ill barely start learning about oil and lubrication next week, but id like to get some advice from you
im thinkin wether i should go to the dealer just to buy the oil
since im not gettin my car serviced there, i feel like they are just going to charge me more than they usually do
the dealers always do this
Old 10-28-2011, 03:04 AM   #2 (permalink)
runtohel121's Avatar
READ your owners manual.. it will say which.. I believe it's 0-20w. I usually go for Mobil 1.. At least for engine oil that is.
For CVT, go buy it from Honda.....
~2010 Honda Insight LX Atomic Blue - 2010-04-25~
~1,000 miles - 2010-07-13~
~10,000 miles - 2011-09-05~
~20,000 miles - 2012-05-22~
runtohel121 is offline   Reply With Quote
Old 10-28-2011, 05:45 AM   #3 (permalink)
If you are used to having oil changed at Honda, keep buying their brand oil. Get 0W20 oil. Buy 4 quarts. You will use 3, then you'll have to use a little out of the 4th bottle.
And you must use Honda CVT fluid. Specify Honda CVT Fluid. Again buy 4. You will need 3 plus a little more.
You will need a need a new Honda drain plug washer. They get changed every time the drain plug comes off. Part number 94109-14000
You will need a new CVT plug washer. It too gets changed with each drain. Part number 90471-PX4-000
You will need a filter for the oil system. 15400-PLM-A01 is desired, but 15400-PLM-A02 is acceptable.
You will need a filter for the CVT. Part number 25430-PLR-003
You can get it all on line from a discount Honda place like Bernardi. OEM Honda Parts & Honda Accessories - Bernardi Honda Parts and Accessories Or you can get it from your Honda dealer and the rest on line. Your dealer will charge more and might not have it all in stock.
By the way, when was the last time you had your cabin air filter replaced? It's located behind the glove box on the passenger side.
Old 10-28-2011, 03:56 PM   #4 (permalink)
hopefully the transmission oil too, since i always hear its really easy, but always too expensive at the motorfiend.com
Did you really not check the owners manual before you posted this? Most of the answers are their, it just seems like you wanted the lazy way.
Hank_Wilson22 is offline   Reply With Quote
Old 10-28-2011, 05:59 PM   #5 (permalink)
Its usually written on the oil caps of most modern cars. I started using Honda brand, then mobile 1, recently got a deal on some quickerstate 0w20, but I use Honda filters. Every now n then dealers will have a special on filters.
I think Enos makes cvt fluid, but I just use honda brand.
Old 11-04-2011, 12:57 PM   #6 (permalink)
I vote for the Mobil 1 0W-20. Full synthetic is the way to go. It may be too late for your class but most auto parts stores run specials on Mobil 1 every couple months. Buy 5 quarts and get a free filter for somewere around $30. Stock up and save! Dealer oil changes use standard oil and cost upwards of $50. So you are putting a much better product in your car at a cheaper cost. Win / Win.
Gatorade is offline   Reply With Quote
Old 11-06-2011, 01:03 AM   #7 (permalink)
ATS*SOL's Avatar
0w-20 mobil 1 havent had any issues.
3.5qt without filter 3.9 qt with filter
* ATSxDPK * Wek'Sos Industries * Franklin Autobody * RyWire * Prestigious MotorWorks * All Star Detailing * R.A.W Spec Wheels * F.C.B. * N1 Concepts *
ATS*SOL is offline   Reply With Quote
