Progress offered me a refund minus shipping if the bar did not fit the insight. If both are the same diameter, then there is no advantage to get the crz over the fit.
Since you got to remove the rear springs to install it, you may want to grab a set of lowering springs too to firm up the ride. Ive seen tanabe go for under 200 bucks on ebay.
