finally!!!!suspension upgrades for the I2!! - Insight Central: Honda Insight Forum
Old 12-07-2011, 03:28 AM   #1 (permalink)
Default finally!!!!suspension upgrades for the I2!!
someone else problably found this site with upgrades for our I2
i was planning of buying the fit rear sway bar for my I2 but know im battling between the front, lower arm bar, and the rear bar
which one is better?
is the rear one more expensive because it works better?
Old 12-07-2011, 02:52 PM   #2 (permalink)
The rear is easier to install, however with ur theme sway bushings the front will be more noticeable.
Old 12-08-2011, 03:23 PM   #3 (permalink)
what about the one that goes in the middle(under the car)
is that one as good as the others?
Old 12-09-2011, 08:01 AM   #4 (permalink)
That is a body brace to help reduce flexing of the vehicle it makes the car feel more solid in the turns and easier to drift.
Old 12-10-2011, 01:54 AM   #5 (permalink)
so its just another sway bar that goes somewhere else huh
hey cobb
do you think the rear sway bar for the I2 requires to get rid of somethin you got rid of when you installed the fit bar?
( i mean a peace of plastic ... i think it was a piece of plastic)
