Help from those with a service manual! - Insight Central: Honda Insight Forum
Old 11-02-2012, 11:04 AM   #1 (permalink)
JamesK-insight's Avatar
Default Help from those with a service manual!
Hello! I need to replace one of my air vents (or outlet assemblies as Honda calls them)... are there any instructions in the service manual on how to do this? I'm conscious not to damage anything!
Worst case it'll be off the dealer $$$£££$$$!
Thanks!
JamesK-insight is offline   Reply With Quote
Old 11-03-2012, 07:03 PM   #2 (permalink)
Is this for the 2010 and later? Where is the "air vent" located? Why does it need to be replaced?
Old 11-04-2012, 02:59 PM   #3 (permalink)
Hi Cobb... it's a 2010 that I have.
The previous owner (idiot!) has damaged the passenger side vent and the vent above the heating control. Looks like they tried to attach something to them with a combination of glue and drilling - bit of a mess!
The price was reflected when I bought the car and I've decided that whilst replacing the two, I'll go the whole way and replace all 4 with the chrome ringed version from the 2011 face lift (and the matching heater ring for good measure!). Got the parts on special order:
2*77630-TM8-A11ZA Outside
2*77620-TM8-A11ZA Inside
And to get the heater control ring to match:
79560-TM8-A02ZB RING, HEATER CONTROL (Chrome)
I.e. looks like http://autocarinterior.com/wp-conten...ew-510x382.jpg
Although I have a RHD version, I guess the same procedure applies!
Any advice is much appreciated!!
Old 11-07-2012, 09:27 PM   #4 (permalink)
Might want to go to your local Harbor Freight or tool store and get some pop panel tools.
Old 11-08-2012, 03:46 AM   #5 (permalink)
Thank you - that's helped me out so much!!!!!! Parts are still on special order but I'll try and post up pics of the result!
Cheers!
James
