As some you might have noted, I am in the process of trying to aquire a 2011 Insight with some 28 miles on it.
A engine heater is a must (all of our vehicles are 'plug-ins'.
Now, do you think an engine oil heater would be beneficiary? I am asking because of the hybrid having to have 'operating temperature' to work most beneficiary. Would it even work considering the panels underneath, I mean, it will get very warm, if not hot, don't want any plastic parts to warp or get damaged.
I used a pan heater one on our van and it sure made a huge difference (even though I used a rather small one).
As you probably suspected, I don't have a garage, that's why the vehicles are plugged in. Warm engine, warm air and with the interior heater, no ice/snow on it.
Sure, a pan heater will benefit any car in a very cold climate as it allows the oil to flow more easily upon start up, thus a lower viscosity. The engine heater normally is inserted through one of the freeze plugs and warms the anti-freeze thus warming the block helping the engine to start easier. A pan heater warms the oil allowing the oil to flow more easily upon start up thus reducing engine wear during a cold start up. Because the oil is warm there is also some block warming but not as much as the block heater provides.
The freeze plug heater is old style, I know you guys still use it here. Our current engine block heaters are tubes inserted in the block, the manufacturer already has a spot for it. Takes 15 minutes, some heat-transferring sealant and a socket, that's it.
Works like a charm, and if you have the directional flow of your dial inside the car set to the windshields, I already have 2 spots free from ice and snow, without an interior heater.
I was mainly wondering about if an oil pan heater would interfere with any parts installed on the Insight, like those plastic covers underneath.
I am not 100% sure, but the oil pan maybe aluminum and you would need a stick on vs magnetic one. Id suggest the oem block heater for the engine and maybe the stick on pad for the cvt.
2 hours in freezing temperatures with the oem heater and my car is up to 100 degrees.
I want a block heater or such for my Insight, but can't source it.
That oem block heater, is that a Honda thing?
Do you have a parts number for it?
I don't know how it translates in Dutch; I bet that if I tell my dealer to get me a block heater, I'd get the same blank stare that I got when asking them for aftermarket HIDs and LEDs. (They triggered on aero wheel covers only to reveal theirs were a complete ripoff and not aerodynamic at all to boot. The garage work is fine though.)
2011 Insight Elegance Accord horn, Waxoyl, HIDs, LEDs, lower grille block, plans for several eco mods
Thanks! At least I can show that to my dealer.
We run 230V over here. This 110V one would get the engine warm very quickly indeed, if my power fuses don't pop first. So I need one for the right voltage.
If I can get a 230V block heater at anything near the price of that one I'd be over the moon.
Reason: Typoooo
__________________ Silver 2001 Insight 5spd - #0160
267+K miles
(Has some bruises, needs some stuff...but I still love it.) Citrus w/ A/C - #2083
270+K miles
... or 1700 Watt when run on 230 volts.
The latter is stick-on. I prefer solid mounting and more power, but easy installment might tip the scale.
Thanks for the tips.
Ebay is a nice medium, just was outside my radar.
