LED replacement bulbs & CANbus errors - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 03-18-2013, 11:07 AM   #1 (permalink)
Default LED replacement bulbs & CANbus errors
I was looking to replace the lighting in my 2012 LX with LED bulbs. Found lots of choices, especially on carid & superbrightleds, but I also read about the dreaded (ok, more like annoying) CANbus errors that sometimes happen when swapping out the stock incans for LEDs. Some of the LED bulbs sold online are billed as "CANbus error-free", but I've also seen reviews where people who used the supposedly error-free LEDs still get the CANbus errors. The fix to the CANbus errors seems simple enough, to use load resistors.
So has anyone experienced CANbus errors after changing the interior or exterior lighting to LED? Or maybe you changed to LED bulbs without any problems & never even heard of CANbus errors before?
Any feedback is greatly appreciated. Thanks in advance.
2012HIn00b is offline   Reply With Quote Quick reply to this message
Old 03-18-2013, 08:10 PM   #2 (permalink)
Nope not a problem with the gen 2 insight. THe ony problem you will have is hyper flashing if you switch out the turn signal bulbs.
Old 03-18-2013, 09:07 PM   #3 (permalink)
That's great to know. Guess I'll be ordering some LED bulbs soon. Thanks for the info.
Old 03-18-2013, 10:16 PM   #4 (permalink)
Basically all you got all the side markers and license plate lights, they are 194 bulbs. The head lights can be hid. The city light in the high beam socket I opted for a 168 amber bulb.
Old 07-13-2013, 11:54 AM   #5 (permalink)
YOU CANNOT replace the upper side marker lamps in the rear taillight assembly with LEDS and no resistance. I've blown out both circuit boards on both sides of the rear tail lights. Once was covered under warranty, the second one wasn't and still is limping along without the 3-side lamps.
Dave23703 is offline   Reply With Quote Quick reply to this message
Old 07-13-2013, 03:01 PM   #6 (permalink)
Interesting..... The first gen 2 s have a single regular bulb in the rear tails. Ive often wondered why the tail/brake is led where as that side marker is not.
Old 11-09-2013, 11:53 AM   #7 (permalink)
I've been slowly replacing all of my incandescence bulbs with LEDs from either Sylvania or Philips when available, if not then from VLEDs. Is there a specific amount of resistance I should use on the upper side maker lamps so I don't blow out the circuits?
2011 Honda Insight EX non-NAV w/ Marimoto 35w 4500k HID, All other bulbs LED, 3M Crystalline Tint (F70%/R40%)
admadan is offline   Reply With Quote Quick reply to this message
Old 11-09-2013, 12:58 PM   #8 (permalink)
I am interested in this as well. I will talk to my Electrical Engineering professor as well.
Sent from AutoGuide.com Free App
2010 Honda Insight EX, Tanabe DF210 springs, K&N Filter, Group 51R Battery, half grill block, custom air intake, 20% tint, rear wiper removed
twulz is offline   Reply With Quote Quick reply to this message
Old 11-09-2013, 06:27 PM   #9 (permalink)
If you are trying to find the right resistance you need to take out the bulb and measure the resistance with a multi meter across the contacts. Since the circuit boards were designed for this resistance, you should be able to put a resistor in parallel with the LED or purchase an LED with the resistance that matches.
I still need someone who can repair my Taillight, any one?
Old 11-21-2013, 01:12 PM   #10 (permalink)
Well I figured, I'd take a risk and if need be bust out the multimeter and soldering iron to repair circuits as needed.
So far all is well. I've now replaced almost all of the bulbs in my car with LEDs (not the one under the shifter yet, that's a pain to get to and will be a spring project and obviously not the high/low beams) including the upper corner red parking lights in my tail lights and nothing burned out.
I wound up using these bulbs:
Standard Red 194 6 LED - Red - 194 - 168 - 158 LED - Miniature Wedge Base - Bulb Type
Their 10 led replacement bulb was too long and wouldn't fit. The 6 led is nice and bright compared to the stock incandescent.
I am curious to see how these led headlights compare to a stock bulb & HID, just not $120 curious.
H11 5K CXA 2000LM | 1 PAIR - LED - Headlights - Bulb Type
9005 HB3 5K CXA 2000LM | 1 PAIR - LED - Headlights - Bulb Type
Random Question
