After a couple of months of having the SOC gauge showing drops of 3-15 bars during normal commuting, not wanting to deal with my usually clueless dealer and researching possible causes on this forum, I thought I'd try a Hawker Odyssey battery as others here have done.
Batteries + had the 545 in stock, along with the automotive adapters: I know I would have paid less on eBay, but time is more important to me than a few bucks, so I got everything there, took my purchases home, and popped the hood.
The Hawker is such a cute bitty thing, waaay too short to stabilize with the existing battery clamp. I might have engineered a deep u-shaped clamp from my stash of metal and aluminum scrap pieces, but I didn't want to devote the time or energy... I even thought of getting a longer ground cable and mounting the thing sideways, but that didn't work either. So for the time being, I cut a 2X4 into 7" lengths, glued them together and sprayed them black, and came up with a lightweight base that raised the battery up oh-so-close to the right height. Eventually, I'll make something more elegant, when time allows... I set the battery on the base, and it was still just a skoosh too short... so I took the OEM battery clamp, stepped on it and deformed it just about 1/4" down, and when I bolted it in place... that did the trick. The battery is now solidly secured, centered on the tray, butted up against the firewall side. Between the clamp and the left (from the front of the car) tray wall, there is a perfectly-sized space for a spare quart of Honda oil.
But how well does it work, you ask? The car started instantly, the SOC went from 0 bars to 1-from-the-top inside of five miles driving, and over the last month,
has not dropped lower than 2 down... and I have even seen
all bars lit twice from commute start to finish. The biggest pain: Reprogramming my fave stations on the radio.
Unexpectedly, and more amazingly to me, even in coolish weather, my mileage has jumped 4-7 mpg over the last tankful... I'm now averaging 60-62mpg with unchanged driving patterns. My LMPG, which has been static at 55.7 for 1500+ miles, is now at 55.9! Coincidence or serendipity? Smarter minds than mine can decide, I'm just waaay happy with the results.
Battery and adapters, <$115.00
Having My Beloved stare in amazement and exclaim, "
that's the battery now?": Priceless
