2005 Insight mod for CA HOV compliance? - Insight Central: Honda Insight Forum
Old 10-24-2006, 12:19 PM   #1 (permalink)
Default 2005 Insight mod for CA HOV compliance?
Hello All,
I just got a 2005 insight and was disapointed to find out it wasn't eligible for CA HOV stickers.
Is there any sort of modification that can be made to make it compliant with the CA HOV requirements?
Thanks for the help.
-Jenya
jenya101 is offline   Reply With Quote
Old 10-24-2006, 01:22 PM   #2 (permalink)
Just apply for the stickers, and you will probably get them. I have a 2005 also, and they gave me the stickers. Good luck!
jbrasure is offline   Reply With Quote
Old 11-11-2006, 05:33 PM   #3 (permalink)
Default HOV stickers
Here in the Bay Area (SF) You first have to get a special Hybrid Fastrac bridge toll transponder. Try here:
http://www.bayareafastrak.org/
After that is recieved you must apply for the new HOV stickers, which can't be mailed until after 1 Jan 07 when the new law goes into affect.
This will qualify you for the HOV lanes but I don't believe you are excused from paying bridge tolls. (Unless they changed it recently)
http://www.bayareafastrak.org/static/ne ... tml#hybrid
The hybrid sticker option was supposed to expire in '08 but I think it has been extended until 2011
'05 New Formula Red CVT , Schukra lumbar support, Toyo 195/55-14 T1-R tires, Holmgren footrest, Wayland sub
RobMason is offline   Reply With Quote
Old 11-12-2006, 03:23 PM   #4 (permalink)
I have stickers on the Insights.
The toll transponders are just regular ones and you can use them in any vehicles you drive.
You do pay a toll, but interestingly it is less than the cash you pay at the booth. I think that is true of all fasttrak tolls, however.
http://insight.fungiart.com/
'01 Red 5 spd w/Turbo Kit 000001 (Edwin)
Yokohama E100s 185/60/R14
'01 Red 5 spd (Jane)
Bridgestone RE92 OEMs
figgy is offline   Reply With Quote
Old 11-14-2006, 01:32 AM   #5 (permalink)
HB
Default Re: 2005 Insight mod for CA HOV compliance?
-Jenya
CA DMV doesn't appear to care what year your Insight is (or else doesn't check). I had no problem getting stickers; but I was sure to indicate my '06 was ULEV (as opposed to SULEV). So if they ever do come after me, at least I didn't lie on the form!
Henry Beecher
'06 Sliverstone 5sp
(last MT in CA!)
HB is offline   Reply With Quote
Old 11-18-2006, 12:30 AM   #6 (permalink)
This link seems to indicate you need the Hybrid FasTrac transponder before you get the sticker, perhaps they are lax on checking .
