I did a hot air intake myself. It's a simple flexible aluminium tube from the exhaust pipe to the airbox. The OEM tube at the airbox gets changed by the alu tube.
63 F outside temperature, intake temp with the OEM tube: 74 F.
With the tube installed I've seen 100-118 F, 26-44 F more.
What would you concern the maximum intake temp? I don't want to burn the car down.
Is 140 F too much?
