Insightcentral.net is the premier Honda Insight forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
» Sponsors
» Sponsors
Old 02-11-2008, 06:11 PM   #11 (permalink)
IamIan's Avatar
Default Re: New MIMA Thread (all MIMA discussion goes here)
Glad to see MIMA back.
I am expecting this thread to get long and have several separate issues being discussed.
00-MT-I1
Modifications: MIMA ( #024 ) & FAS
Battery Hobbyist
Renewable energy enthusiast
Old 02-13-2008, 05:42 AM   #12 (permalink)
IamIan's Avatar
Just curious if other MIMA users ever / regularly use the EV-MIMA mode? And what the ranges / conditions are that they use it in?
On a particular section of road during my commute to my companies new building I find it is useful as coasting or FASing will slow down... but a low speed 3rd or 4th gear and a little MIMA , about 1 or 1.5 red lights and I will maintain speed without additional gas.
To those who don't know about it:
when MIMA has the IMA give more assist... if the assist is large enough compared to the currently required load ( no matter what gear you are in ) the Insights stock fuel cut mode will engage and you will be in a PURE EV mode of operation... this is easiest to see on the metric display ... You can also tell you are in MIMA-EV mode if your foot is off the gas and your RPMs are around 2,000 or more... it is not all sunny though... since the ICE will continue to operate as an air pump you will waste some of your energy just pumping air.... and of course without an outside source of Electricity for a V-boost type of system the power needed to get into the MIMA-EV mode still all comes from gasoline consumption.
00-MT-I1
Battery Hobbyist
Old 02-13-2008, 11:46 AM   #13 (permalink)
joecvt's Avatar
I have used the MIMA "EV mode" when stuck in snow and the tires start to spin. I have a CVT so I don't have the option to start out like a manual in second gear to reduce some torque from the engine. There is alot of torque in the begining when starting out in a CVT...So I just leave my foot off the accelerator and use the MIMA pedal for assist only to slowly start the car moving then I'll use the acellerator a bit more. So I call this mode sort of a MIMA traction control
The only other time is when showing my friends what it can do in "EV mode" but it does bring the battery down quite a bit when doing that so I don't do it often.
JoeCVT - Just your average CVT owner
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Old 03-06-2008, 11:18 AM   #14 (permalink)
Hybrid Technologist
gpsman1's Avatar
I am going to purchase an Insight very soon.
So I will probably want MIMA in the near future ( maybe be 9th or 10th on the wait list??? ).
To Mike the inventor... I am buying this car because I perceive it to be one of the simplest hybrid models to hack and modify. Would you agree with this assumption? Also, due to its aluminum shell and light weight, I feel down the road, it would be one of the best chassis for possible all EV conversion, do you agree?
Lastly, would you find MIMA to be an advantage down the road, if I wish to custom build my own battery pack?
Just curious, but it sounds very promising.
My other car is a FEH and I get about 54 MPG in city driving, in mild weather in that 4,000 pound "brick".
But the Fords look like much more work to "hack".
Thanks!
Hopefully I'll be in the club in a couple of weeks.
-John
Old 03-06-2008, 05:56 PM   #15 (permalink)
Mike Dabrowski 2000's Avatar
yes it is the easiest to hack, it will make a nice running chassis for a full electric, and MIMA is likely the best way to take advantage of more electric capacity as a hybrid.
Mike
Mima Insight MT # 007 2000 5sp AC
Grid/solar charged 48V "Eboost" battery
Drop down "Ewheel" EV 5th wheel.
low price grid charger
http://www.99mpg.com/
Old 03-06-2008, 06:05 PM   #16 (permalink)
IamIan's Avatar
Thanks!
-John
I won't speak for Mike or those who also worked on the development of MIMA But this is my 2 bits.
Of course any Hack or Mod risks voiding warranty and killing you or your car.
I think Insight is the easiest HEV to hack and for after market modifications... there are fewer of them so don't expect as much pre-made modifications as other HEVs might get.
I almost got a EV conversion of my pre-Insight car when it died... a 1990 Chevy Cavalier ... but in the end at the time what I could afford for the EV conversion would not have met my driving needs at the time... so I got the Insight instead... which I think is a great platform for conversion to EV... there are very very few cars you can buy that can beat the Insight for Low weight and aerodynamics...
My plan is more of a PHEV conversion.
MIMA was great because it gave me the control of the IMA motor that I wanted to have.
I have been planning and studying to do a small high voltage booster battery to make my Insight a PHEV... I live in an apartment right now so any battery I want to plug in I have to be able to remove from the car and carry into the apartment to charge up.... this greatly limits allot of my options... Lead Acid is way to heavy... NiMH is doable... I estimate the removable PHEV booster battery will weigh around 60 Pounds... Li-Ion would be about 3 to 4 times as much money as NiMH but would reduce that removable PHEV booster battery down to under 40 pounds...
I look forward to using my MIMA and the second battery to offset more of the gasoline I would have used to go the same distance.
After the PHEV booster battery is done I plan to continue to make more mods for my insight that will push it more and more into EV range and allow even more electric priority operation with the help of MIMA.
Even if I end up doing a full EV conversion I like my insight for the vehicle... I like the included 10kW IMA motor and the motor controller with regenerative braking ... the included DC-DC module.... lots and lots of nice stuff.
00-MT-I1
Battery Hobbyist
Old 03-09-2008, 08:50 PM   #17 (permalink)
My waiting list requirement of 10 people has been reached. I am starting the reordering process.
People should continue to send in the forms, so I will be better able to decide how many to build.
25-50- or 100? How many more Insights will want one?
How long before we are drawn to the Aptera and other cars of the near future, and we will abandon our Insights?
Tough decision.
I don't expect to ever build another batch of MIMA after this.
Mike
Old 03-09-2008, 11:58 PM   #18 (permalink)
Hybrid Technologist
gpsman1's Avatar
Hi Mike.
I am picking up my Insight next weekend.
I'll need a few weeks to get used to it, and a few more paychecks, before I can buy MIMA.
However, you can count on me to buy one for sure, which will be around June of this year.
Is it true that I can reset the "lifetime" MPG meter myself? Or do I need to ask the dealer to do that before I drive it home? I would like to know my lifetime number, not the previous owner.
But yes, I will buy a MIMA, and a FAS if that is a separate component.
You can count on me. I've been dreaming of ( and tinkering with ) manual control of my Ford Escape Hybrid.
I'm so glad MIMA is available!
-John E.
Old 03-10-2008, 09:32 AM   #19 (permalink)
Just send in the forms to get on the list.
Yes you can reset the LMPG easily, it is in the owners manual.
Mike
Mike
Old 03-15-2008, 07:53 PM   #20 (permalink)
Newbie. Hope I do it right
I was reading about MIMA some. I am still foggy on how it works. Can it be used on CVT? Can a person use the electric engine sooner?
sk8sc is offline   Reply With Quote
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
